OKTRX450R
Jan 19 2005, 11:55 PM
[SIZE=7] Honda HRC Kit for the 04 / 05 TRX450R
Description-- Part Number-- Notes
HRC TRX450R PWR-UP-- 06100-NLZ-660-- Complete Kit
SET-UP MANUAL-- 00X31-NLZ-6600
LID, AIR CLEANER CASE-- 17217-NLZ-650
MUDGUARD, ELEMENT -- 17218-NLZ-650
WASHER, PLAIN 5 MM-- 94103-05800-- Qty. 2
SCREW, TAPPING 5 X 20-- 93901-25420-- Qty. 2
CAMSHAFT COMP.-- 14110-NLZ-650
ARRESTER COMP., SPARK-- 18317-NLZ-650-- Muffler End Cap
GASKET, MUFFLER-- 18292-MV4-000
DUCT, SNORKEL-- 17259-NLZ-650
JOINT, BREATHER 3-WAY-- 15771-NLZ-650
SET, CARBURETOR SETTING-- 16020-NLZ-651-- Both jets together in one kit.
MAIN JET, #185-- 99101-3571850
NEEDLE SET, JET-- 16201-NLZ-651
#8trx450r
Jan 20 2005, 03:01 AM
Most of these #'s do work on the servicehonda site. The needle kit is only $23, the end cap is $103, the cam is $214 and so on. Just figured i would post the most desired parts prices
Service Honda8
UFOmile450r
Jan 20 2005, 04:22 PM
Did god sent you? Because i was just going to make a new topic asking this. I only need the cam and needle. Thanks man!
#8trx450r
Jan 20 2005, 04:30 PM
QUOTE(UFOmile450r @ Jan 20 2005, 04:22 PM)
UFO, if all you need are those two things you would still be better to buy the whole kit. You can nab one off Ebay for under $200 if you are patient
8
Uneasy Rider
Jan 20 2005, 04:43 PM
QUOTE(#8trx450r @ Jan 20 2005, 01:01 AM)
Service Honda8
DANG! $103 for the endcap????
#8trx450r
Jan 20 2005, 04:47 PM
QUOTE(Big Slick @ Jan 20 2005, 04:43 PM)
Service Honda8
:lol: :lol: I know WTF?
8
UFOmile450r
Jan 20 2005, 04:50 PM
QUOTE(#8trx450r @ Jan 20 2005, 04:30 PM)
8
Yah, now that i think about it, the only thing i DONT NEED in that kit is the end cap. So i might as well buy the whole kit. Ebay, here i come!
Hope i dont get ripped off
450rbeast
Jan 20 2005, 06:28 PM
I thought 16020-NLZ-651 was the needle kit.
OKTRX450R
Jan 21 2005, 10:53 AM
Sorry, maybe I did not make that clear enough...
This part number is the bag that contains the HRC Needle and the 185 main jet as wppracing stated. Inside this bag are two other bags...one has the HRC Needle and its part number and the other is the main jet and its part number. I just listed them all so if you wanted both parts you could order the SET and if you only wanted one or the other you would have the part numbers for each.
crobiker
Jan 27 2005, 02:01 AM
UFO: if u already have the endcap, and are gonna buy the whole kit, i will gladly buy just the endcap off of you. they check for spark arrestors where i ride and i hate putting the stock one back in and re-jetting it. PM me if you're interested.
UFOmile450r
Jan 27 2005, 07:23 PM
QUOTE(crobiker @ Jan 27 2005, 02:01 AM)
Ill buy it in a few weeks so if you want the end cap ill be happy to sell for cheep, so in other words, ill sell it for what it should be, not 103$
. Thats just crazy
Tripyn
Nov 4 2005, 10:33 AM
Could someone post the part numbers for the 06 kit? I am only looking to open the air box a little and rejet. Can't seem to get a stright answer locally on what parts I need to acomplish this. I want to try these 2 mods first and then go from there. Any help suggestions would be appreacaited!
KillerQuad
Nov 6 2005, 08:50 PM
QUOTE(Tripyn @ Nov 4 2005, 10:33 AM)
[right][snapback]154833[/snapback][/right]
There is no Air Box lid or modification to the air box at all with the 06 HRC Kit....
That is somthing that you might have to work with yourself.....
sandshots
Nov 8 2005, 03:25 PM
QUOTE(#8trx450r @ Jan 20 2005, 01:30 PM)
[right][snapback]51218[/snapback][/right]
8
[right][snapback]51225[/snapback][/right]
has anyone seen the hrc cam cheaper? or in stock?
just got back from the dealer, they have 50 on order with no ET.
I want it in by thanksgiving, that means its gotta be done with in the next two weeks.
atvaddict01
Apr 26 2006, 05:34 PM
Im looking for pilot jets for a 04 keihin 42 mm carb.For some reason
noone can tell me the type of pilot jet i need to buy.Apparently there is two sizes a long and short.Any help you guys could give me would be great.Thanks alot
Greg
bennettjoh
Dec 5 2006, 09:24 PM
I bought a used 2006 ER. After looking closer, the bike appears to have the HRC kit installed. ie. a larger end piece on the exhaust. It is also missing the small air chamber that attaches to the side of the airbox, there is a block off in its place.
What else should I look for to be sure if this bike has the HRC kit or not?
What would happen if I re-installed the stock exhaust end piece and the stock airbox lid?
I also noticed that the snorkel that attached to the airbox lid is gone so the airbox lid just had a hole where the snorkel would be.
Gumby46
Dec 5 2006, 09:44 PM
This thread is actually for the 2004 2005 HRC kit, so it will be different.
Sounds like it doesn't have the actual kit installed because it should have a new snorkel. Sounds as if they may have just installed a new cap on the exhaust.
Do you have a way of taking some pictures?
Gumby46
Dec 5 2006, 09:46 PM
You should take some pictures and give detailed descriptions of everything and start a new thread. There are plenty of people that can help you determine what your new ER has and what is NEEDS!
This isn't the best place to keep talking about it.
new2honda
Sep 26 2007, 06:23 PM
i recently bought an 08 450r and the local honda shop told me that the 2008 hrc has a different part # than the 06/07 and they "are not available yet". i thought that 06-08 450r's were the same. any ideas?
vince
Nov 7 2007, 10:26 PM
QUOTE(KillerQuad @ Nov 6 2005, 08:50 PM)
how is it then that on page 1-6 of the hrc set up manual,it states that you Remove the air cleaner housing cover and retainers, for what purpose would you do this ?
Calta450R
Dec 3 2007, 05:51 AM
Sorry to bring back from the dead but I was wondering the same thing. Anyone?
