another day back at the dyno guys...and since we all know im a 300lb rider with a near full weight bike i have nothing to hide from ya all...and therefor will always share my results with you guys in the interest of learning and making these tech sites a better place to be...
OKAY...day started off way hotter than a couple weeks back which had me nervous that jetting might be a bizniggle...but i correct a few things from last time and i knew in my heart i could nail 60 this time with no changes other than a couple little things i noticed...unfortunately im a dumbass and lazy and still have the same damn spark plug in there that has been in for a year...and i did not change my oil from memorial weekend...but...i will say that rotella T holds up pretty good as the oil was still clear and looked great
FIrst up i dynoed with my same ole modded ESR ( i did myself...i dont know if mixxer is better at it...but it passed his inspection....i managed to pull a best of 60.0 horse and i broke 36 lb feet of torque again..but on the one run i copied i was a 59.7...so it was good news out of the gate to hit 60 on the existing setup like i predicted before
NEXT UP
FCI...the first FCI i put on was the one without the insert...(insert is ablack piece of plastic that reduces the volume of the intake to creat more airspeed and is closer in volume to the the ESR)
my bike HATED THAT intake...i had A/F readings ALL OVER THE PLace...and it point blank lost horsepower EVeryWHERe...i tried 3 different jett changes and the harmonics and intake speed were just all off...
after that
i tried the FCI intake that does have the insert...i had a feeling it would work better and so did garret ( i was on the phone with both mixxer and garrett multiple times today to give updates and to get any advises and put our heads together on what would or would not work)
the FCi with the insert right of the bat was pulling great A/F ratios...and was very clean through the band like my ESR was...
i knew there was some potential now so i really got to tuning and even cut a 1/4 inch off the carb side of the intake (which got my best results!)
the peak horsepowers between the two intakes where VERY close....60.3 out of the FCI and 60.0 out of the ESR...im sure it could have gone either way had i spent the whole day tuning both out to the max....HOWEVER...the real story here goes to the FCI making a buttload better torque quickly in the power band and holding it to the peak....i gained over a horse most of the band...and in some gases more than a horse as well as torque...peak torque was 37.3 which is not to shabby for a 478 yfz...
this just goes to show how important it is to test mulitple variables and how even a 1/4 can make a difference at times...and if you have a dyno local to you you may just be missing out on a bunch of power if your not getting the facts with a good A/F reading
end of the day prooved that the modded ESRs rock! they are hella cheap and make great power
but...if you can afford a couple hundred bucks the FCI may just proove to be even better...quality is top notch...i have a wierd situation with mine cuz my bell on my carb is far larger than normal...but with some fine tuning and a little bit extra customization my FCI will be here to stay and i have a modded ESR up for sale....i really like the economical aspect of the ESR...but unfortunately our YFZs have a tendancy to rub through the outerwears of the ESR and with time that could be detrimental to the livlihood of the engine...
AND I WANNA MAKE ONE THING VERY CLEAR
thoughout the day mixxer (please dont turn my thread into a bash fest or i wont share anymore) but john was all for my FCI testing and was bummed the first go around when i didnt get gains and the first intake sucked...and he was VERY happy for me when the results changed with the second filter...so if you think he is anti FCI its just not the case....HE as well as GARRET both have and had the attitude of compare and run what works best...and garret did not freak either when his first tube sucked donkey balls...he was calm as well and just wanted me to be happy and get the results i wanted...garret would have been A O K if the ESR pulled better...and mixxer was A O K with the FCI ending up being the better fit for my motor so lets all please not even go there on this thread
thanks!
sredrum...i got there first buddy! hehe but i hope your at or above me really fast cuz you da man
thanks obviously to VENOM and their badddasss headwork
thanks to KBR as always
thanks to Chris (sredrum) and his great carbwork
and now thanks to garret at FCI for a great product in their intakes
we can all get along and play nicely...and make horsepower in the process
oh yea...and i got hotcams and a pulsecharger LOL...booooyahhh! i bet i hit 70 with some webs and a dragpipe ...just kidding...nobody take that the wrong way...just a joke to ease the tension of all the bickering lately...to each there own
first dyno graph 5 runs from the day....FCi intake with insert...just wanted to show it was repeatable
second dyno graph FCi shortened with INsert Vs esr
third dyno graph FCIs best run of the day
fourth dyno graph ESRs best run of the day
and i realize the A/Fs are not matched...but lets face it...i dont have the time for that much fine tuning...and they are different so they will never be the exact same...
6 or more jet changes today...and multiple intake changes...and im ready to go ride now
edit...oh yea...gas...91 octane with kemco oils octane booster...no u4 or u2...just mix my own gas at home...wanna try the u2 some day for giggles or even methanol....but i hate spending so much money on gas
