Full Version: utility guys
Honda TRX450R Forums: Honda TRX 450R Forum > Other Quads > All other quads
DN1911
i mounted a plow on my Bombardier Outlander 400 and after about an hour she started to get hot. any ideas on how to keep her cool. i know i need to check to radiator and see if it is clean but even if it is a little clogged, i still wouldn't think that it would get that hot in 20 degree weather.
#8trx450r
Was this an hour of steady plowing??? If so that may just be normal, plowing is pretty stressful but I would check the normal stuff like the coolant level, Coolant flow, Thermostat if it has one, fan if it has one and so on. Hope this helps.
8
Trx450always
The reason might be that you are going at a very slow speed with a lot of stress on the engine, or the plow could be blocking air flow to the radiator. Both could also be possible. I don't think there is a fix for that problem unless you install a fan?
DN1911
well i took the front end off and found a clogged radiator, that's what i get for lettin the GF clean her quad. also it does have a fan just it isn't working. the bike is at the shop and should be back soon. i hear there is more snow coming so i hope they hurry.
