and let's start it right here and now, first time ever, on this very website
let's make history!!
being governed by physical laws, we compare specs on all engine components to get an idea on how it will perform, based on what we have seen happen with such changes in specs in the past.
that's why we can predict with reasonable certainty what will happen when we change things like compression \ cam duration \ carb size \valve size \stroker cranks etc..etc..
we all want to know the specs on our original component, and the specs of our intended higher performance replacement for it. that's how we can determine if it will perform in the way we wish to go with our mods :ph34r:
that's why we want to know what the specs are on everything, such as a new cam b4 we buy it, if the specs aren't different from what we now have, and in the direction we wish to go, we wont waste our money buying it ,......right??
well guys, you can do the same exact thing with an exhaust system!!!
an exhaust system is basically a confined space, for the spent gasses to travel in,
........from the cylinder head to the atmosphere :huh:
all that matters for power characteristics are the lengths, and diameters, that make up this exhaust pathway...... it's just a tube with some differences in diameter along the way
and inside dimensions are all that the gas "sees", so that's all that really matters, not the outside at all, ever , in any way.......... to infinity and beyond :D
the pipe manufacturers don't want anyone to think about, or compare such things, because they don't want anyone to be clued in on those facts.
that's why you can get so much information on other components, but nobody tells you anything dimensionally about their exhaust systems. they SHOULD, since those specs are the only thing that determines ANY difference in power output
once you know the dimensions of pipes , you will be able to "read" their power characteristics just as you do for any other power part you buy now. once ytou know the dimension\power of one pipe you know the power for all other pipes of the same dimensions!!!
the same way you wouldn't find 2 identically spec'd cams and expect different power from one over the other, neither would you see any difference in 2 different brands of pipes with identical dimensions................ except for the price
of course!
so let's start the revolution here and now :D
let's begin to speak of pipes dimensionally, just as we do ALL other engine components. ask the manufacturers to start posting pipe specs
and when they refuse, and they will, get out your measuring tape and calipers and check the dimensions yourself and help out your fellow man by posting that information
after all we don't merely say " i bought A piston, or A cam ...and it did this......"
.................. we tell the specs\size ...and then tell what it did
or we can continue to do it the way the manufacturers would rather we do it and continue to give three word reviews...... "sparks rules , dude!!!"
............mixxer
would one of you admin peeps be so kind as to pin this..... pretty pleeeeeeze!
