dart450r
Dec 14 2004, 09:55 PM
i'd like to see if there is any hp difference in this set-up..i've read someones post that says it gives it a couple hp...hopefullly mixxxer will get one of these soon so i can see it on paper... if it doesn't give any hp numbers... i'd like to say it feeels like it does....people that alrerady have this besides me... post what you have and your thoughts.... even people with a lightened flywheel... please reply
trxjwb
Dec 15 2004, 03:25 PM
I noticed a huge difference with my -4 oz flywheel from trailtech, I can only imagine a ignition paired up together.
ArntEirik
Nov 13 2005, 06:05 PM
QUOTE(dart450r @ Dec 15 2004, 04:55 AM)
[right][snapback]39457[/snapback][/right]
Is it only to bolt on a crf ignition on a trx?
No other changes need to maked?
Arnt
Trx450always
Nov 13 2005, 07:00 PM
side case needs to be machined. thats it. everything bolts right up.
jsl2003atv
Sep 2 2006, 12:51 PM
i would also like to know the advanteges i was looking as the sparks kit
86atc250r
Sep 3 2006, 12:33 PM
Do a little searching, lots of info on the subject here on the forum as well as dyno runs.
Be aware that a dyno can't always show you everything that's going on & a flywheel is a good example - discussion is archived on the forum.
pudamac12
Jan 21 2007, 11:13 AM
i have it and even though trailtech says it doesn't add any horsepower it does allow the engine to rev a whole lot faster. the seat of the pants feeling is like going from a stock pipe to a full system. It gave my quad a hit that is as hard as a yfz but still smoother then a yfz so it doesn't tire you out. It just revs so much better and it never bogs down in corners no matter what gear i am in. I personally say worth every penny spent.
Maul Tech ATV
Jan 24 2007, 09:17 PM
The CRF flywheel must also be modified!
Ex_Rider43
Jan 25 2007, 01:00 AM
what do you need to modify on the flywheel , Im machining the cover on friday night and thought that the flywheel was bolt on ?
yfz/ltr
Jun 26 2007, 06:37 PM
if your motor is built dont even waste your money, i tryed the trail tech kit on a built trx i had a couple of years ago and after hacking up my entire harness '' you have to in order to install the TT kit'' i did some runs at my usual riding spot racing the same friends with the same bikes and that kit didnt anything whatsoever not even a little for performance, i had to put a little bit of a fight to get my money back from the supplier but i got my $700plus back but i had to purchase a oem stock harness$200 because my original harness was worthless after hacking it up for the install, let me tell you it was a nightmare....... it may be an improvement on a piped or mildly modded bike but i can tell you for a fact that this kit is worthless on a fully built bike
