Full Version: VENOM PORT WORK
mixxer
i want to have a pinned thread with this stuff in it so it will hopefully answer a lot of questions i routinely answer.....
Porting Service:
a) Porting + Polishing + combustion chamber re-working = $525.00
b) Venom will also cut fresh valve seats for NEW valves at no extra charge if done at the same time as porting...
c) New Kibblewhite valves are usually $35 each for the SS Black Diamonds...
d) Kibblewhite Valve Spring kits with Tiatanium retainers go for $210 for 4 valve heads....
e) seat cutting and bowl work for +1mm oversize valves runs an extra $50 per valve..... and no, oversize valves are not necessary in almost all applications
Turn Around Time is usually less than 3 weeks from receiving the head...to getting the head shipped out the door.... we always do our best to get work back to customers in a timely fashion....
What to ship:
1) the head with only the valves and springs left in it.... please do NOT send the shims ...buckets...spark plug...cam towers...etc..
2) include a note with : contact info... full list of mods....intended use of machine...
3) IMPORTANT notice!!!.... styrofoam packing "peanuts" are the work of the Underworld (styro peanuts are the official packing material of Hell) ..... there will be an extra $20 "shop floor exorcism" charge added to any heads that come packed in styrofoam peanuts!!.... J\K on the charge...but please don't pack in styro peanuts if you can help it...
payment can be Cash...Check...Money Order...PayPal...Credit Card....or cash slipped under the door after hours....
BIG DISCOUNTS ON PERFORMANCE PACKAGES ARE LISTED ON WWW.VENOMPERFORMANCE.NET
and now a couple pics of port work...just for entertainment purposes
Click to view attachment
sredrum
Looks good John and VERY fair prices BTW. Lookin forward to having you make my +1 YFZ head. Keep up the good work and congrats on the latest wins at 4SW's.
Gumby46
Makes me want to go home and pull my head off! DAMN IT!
Nice little advertisement thread there John, very effective!
Just need to get rid of those 5 valve things! LOL j/k
mrcribbs
How about some more info on your pistons... what is different than what other companies offer, pricing, etc...
also... why isn't this pinned?
mixxer
QUOTE(mrcribbs @ Mar 7 2007, 06:24 PM) [snapback]347886[/snapback]
i'm sure it will be pinned soon...
all you have to do is hit up the search function to find tons of info here on the HammerHedz and Venom pistons...
lots of threads...
mrcribbs
thanks?
the search function on this site sucks (in my opinion)
but I did find some info...
mixxer
ttt
4wheelman
Mixxer
I read the one about sweet talking the secretary, My 06 R took a dump on me before I left for baghdad, I get back in the middle of Nov, can I still get that pricing? Also how do you guys stack up to the claimed 53 pony's that CT makes out of their Baja package? I think I need a new piston as I believe there is no compression and I could not even pull start my R. I figured that I would get porting done at the same time. The exhaust pipe was glowing red right before she quit, any advise? thanks for all you great prices.
Dustin (4wheelman)
USAF in Iraq
mixxer
just call & talk to Tress......
she will make a note of your time frame \ appointment......
53HP is no problem at all...... and nobody's powerbands are wider than Venom's..... so your 53 would come with a killer curve to go with that peak number.....
you need either the HRC jet kit.... or all the jets from the same year CRF dirt bike carb...all the stock jets\ settings are too lean......
added to the pipe you already have:
Hot Cams stg2 + Venom porting +Venom piston....along with correct jetting...will get you your 53HP and a killer powerband to go with it
4wheelman
great will talk to her, what size jet do I need already have it jetted for for full pipe, velocity filter with no lid. and do you think the piston, porting will fix her? hot cam with the rest, you can do all that or do I need to buy the hot cam stg 2 somewhere else. Also is the piston and all hard to install? Thanks again, appreciate the reply.
Dustin
mixxer
i have hot cams in stock...no problem there
everyone needs to learn sometime...but i don't recommend anyone without experience doing a piston install.... 99.9% of the big mistake failures come from inexperienced tuners......
and even though i have been doing this stuff my whole life (i'm 46).... i ALWAYS buy an OEM service manual for every machine i deal with.... better $$ simply cannot be spent .....
4wheelman
Thnaks Mixxer, will buy the manual, talk to you soon for stuff.
Dustin
mixxer
cool beans....
i'll wait right here .... :)
zippy180
QUOTE(mixxer @ Oct 25 2007, 07:27 AM) *
cool beans....
Hey,
I am just wondering how much it would cost me to have you port and polish the head of my 04' trx450r put in one of the 12.25 pump gas pistons, install a stage 2 hot cam, and jet it. My warranty is expiring so it is time to go into the motor. I have experience working on cars as i worked at a dealership for about 5 years during and after highschool but better opportunity took me away from cars about a year ago. I dont have a lot of experience working on small engines though!!! unbolting block halfs, what is that?!?! I worked on the cadillac northstar and it wasnt like that. so any help would be awesome.
thanks
chad
mixxer
that pic of your machine looks like it was taken in celery flats in portage.....
dump those cast wheels asap.... it's like bolting 2 huge flywheel weights to your axle...!!
the best place in michigan for parts & service is Cycle Addictions in Galesburg 269 344-7944... ask for Anthony....
zippy180
QUOTE(mixxer @ Jan 9 2008, 07:06 PM) *
Actually i took the pictures in my driveway but i used to roller blade on the celery flats along time ago. I have some haulers coming on douglas wheels. I am letting my cousin run the sandstars on his predator. They work great from side hilling and cruising around but really bog my quad down in racing. I got the set for 300 dollars with 1 trip on them, i guess some guy bought from from paw paw cycle for his 300ex and didnt like them so i bought them up for cheap. Hopefully here soon i can throw one of your 12.25 pistons and a port job on my quad.
thanks for the advice.
h0nda450mainiac
QUOTE(zippy180 @ Jan 14 2008, 12:32 PM) *
pretty much i want my bike to be ported and still as reliable as the honda name. what would it take and what would it cost ? : )
Live2Ride199
I am pretty sure that it is 350...... You can rest assured that John won't sell you anything that is unreliable......
mixxer
QUOTE(h0nda450mainiac @ Mar 11 2008, 09:22 PM) *
more power is always more stress on an engine..... no 2 ways about it.... if they made zero power they would literally last forever.....
it doesn't matter what you do to increase power either...whether it's a pipe or a cam or an air filter....more power is always more stress....
porting is $375
blackdrag450r
maybe we should inform people of the new price????
NHRAdragracer
OK
From the website:
Venom porting alone is now $525.
Venom porting with Venom pipe package: $825 (Which basically brings the porting price down to $330)
Later- Kris
mixxer
thanks kristopher!
the website was updated before anything else..... :)
prices are also on the order form that you download from the website to send with heads\carbs\cylinders....
so not exactly a closely guarded secret....LOL.....
D Bergstrom
QUOTE(mixxer @ Feb 23 2007, 11:51 AM) *
BIG DISCOUNTS ON PERFORMANCE PACKAGES ARE LISTED ON WWW.VENOMPERFORMANCE.COM
Might want to fix the website address, it is actually .net not .com. thumbup.gif
Doug
mixxer
got it...thanx doug!
mixxer
04-05 YFZ combustion chamber and intake port....
mixxer
06 & up YFZ450 combustion chamber and intake port
