Chuck's 06 450
Feb 11 2007, 06:57 PM
Well, since I had a hard time getting all the info I was looking for in one place, I want to put together a paddle tire weight list. This is what I have so far from other members posts - as well as my own measurements.
21x12x8 Padla Brats Comp cut on 8x8 .125 rims = 9.5 lbs
20X10X8 6 paddle std buff Haulers on 8X7 .125 rims = 10.25 lbs - Old style Haulers
21X12X8 6 paddle std buff Haulers on 8X8 .125 = 11.5 lbs - Old Style Haulers
20x10x8 btb 8 paddle Gliders on .125's = 12 lbs
21x12x8 btb 8 paddle Gliders on .125's = 12 lbs
21x12x8 8 Pad Gliders std. buff (significant wear), 8x8 .125 = 12 lbs 2 oz
22x11x8 7 paddle glider standard buff on douglas 8x8 .160 wheels = 12 lbs 3 oz
21x8x10 Dune Tracker front, 10x6 2+4 DWT Black .160 = 12 lbs 12 oz
21x12x8 7 paddle std buff Extremes on 8x9 .125 rims = 13.0 lbs
20x10x8 6 paddle std buff Extremes on 8x8 .125 rims = 13.0 lbs
21x12x8 8 paddle Gliders on .160's = 13.50 lbs
21x12x8 8 paddle Hauler/Glider mix on .160's = 13.50 lbs
20x11x8 8 paddle Sand Devils on .160's = 13.75 lbs
22x11x8 8 paddle Haulers std buff on 8x8 Douglas .125's = 14 lbs
20x10x8 6 Pad Haulers std buff , 8x8 DWT Red .190 = 14 lbs 13 oz
20x11x10 Sand Skate II's on 10x8 .125 rims = 14.5 lbs
20-11-8 Sand Sharks on .160 rims = 14.75 lbs
20x11x10 8 Pad STU Sand Skate II, , 10x9 3+6 .125 = 15 lbs 7 oz
21x12x8 8 paddle Desert Storms on .190's = 16 lbs
20x11x10 Sand Sharks on 10x9 .125 rims = 16.75 lbs
20x10x10 8 Pad Hauler Extreme std. buff , 10x9 3+6 DWT Red .190 = 16 lbs 14 oz
21x12x8 Cheng Shin Dune Slider, 8x8 .125 = 17 lbs 10 oz
20x11x10 8 Pad Sand Sharks , 10x9 3+6 DWT Black .160 = 17 lbs 11 oz
20x11x8 GBC Sand Devils on .160 = 18 lbs
20x10x10 Geckos on .125 rims = 19.25 lbs
20/11/10 7 paddle Extremes on Douglas RED label with OMF beadlocks = 19.50 lbs
If you can add more to this list, please do. I will add it to the top as info is added...
For all the std buff entries, it seems that an Ultra-light buff will drop the weight by 2 - 3 lbs...
Raistlin 12
Feb 11 2007, 08:43 PM
20x10x10 geckos on douglas .125 rims are 19.25 lbs each. Just sold mine, so i know.
My new 20x10x8 standard buff 6 paddle extremes are 13 lbs each, on douglas .125 8x8 rims.
450RRR
Feb 11 2007, 10:06 PM
all I could add is that my 20/11/10 7 paddle Extremes on Douglas RED label with OMF beadlocks were 19.50 #'s.... EACH...
and my comp cut Brats...21/12/8 on 8x8 Douglas .125 were only 9.5#......you mentioned 10.5#... what wheels were you using? just curious....
Greg
Chuck's 06 450
Feb 11 2007, 11:17 PM
I am correcting my numbers to reflect the above posts. Greg, I thought yours were 10.5? That's what Sand Tires Unltd says the weight is.... comp cut on 8x8x .125's.... are you sure?
jasmoore3
Feb 13 2007, 01:42 PM
sand sharks: 20-11-8 on .160 rims = 14.75lbs
BadinBlack
Feb 13 2007, 02:42 PM
info is gladly appriciated here.
450RRR
Feb 16 2007, 07:21 PM
QUOTE(Chuck @ Feb 12 2007, 12:17 AM) [snapback]337838[/snapback]
Chuck.....I just weighed my Brats again.....
9.6 and 9.7# each after adding Slime...... on a digital 10# scale...so it should be accurate.....
on 21/12/8 comp cuts mounted on Douglas .125 (blue label) 8x8 wheels using metal valve stems.....
p.s...thanx for starting this thread.....great info......Greg
Fast1
Feb 16 2007, 09:33 PM
Chuck
the weight you have for the 21X12X8 6 paddle haulers, which I believe are mine, are not available anymore from Skat in the type of tire carcass I have. New haulers in this size and paddle configuration may weigh ~ 1 lb more
sredish
Feb 16 2007, 11:32 PM
Chuck, keep your first post updated with the info as people give it to you and I'll sticky this at the top for a reference.
Edit: oh, it already is, thanks Greg. Anyways, guess my job's done here...
quadwanter
Feb 17 2007, 01:18 AM
GBC sand devil 20x11x8 on .190 @ 18lbs
er forgot my scale was off by 5lbs....i was like how are they only 13lbs lol...so they are in the 18-18.5lbs range
Chuck's 06 450
Feb 17 2007, 06:07 PM
updated above and listed in order of weights
hawk-trx
Feb 27 2007, 12:29 PM
10.25# doesnt sound right for the 20-11-8 6pad reg buff haulers even the old style. if they were UL or triple buffs i would belive it. but std. buff?
screwyfits
Mar 16 2007, 05:03 PM
I'll be gett'n some ITP sand stars on monday Mar. 19th and I'll get ya the tru #s...... but shipping weights (from UPS tracking) on two fronts (22-8-10) mounted on cast alum. rims 25lbs (for the pair) and the rears (20-11-10) mounted on the cast also @ 30lbs for the pair....... I'm unsure of the rim manufacture and model........ they were $388 on my front door step,for the full set......"NICE"
Sandstorm
May 10 2007, 10:24 PM
20x10x8 btb 8 paddle Gliders on .125's 12lbs ea
21x12x8 btb 8 paddle Gliders on .125's 12lbs ea
21x12x8 8 paddle Gliders on .160's 13.50 ea
21x12x8 8 paddle Hauler/Glider mix on .160's 13.50lbs ea
21x12x8 8 paddle Desert Storms on .190's 16lbs ea
20x11x8 8 paddle Sand Devils on .160's 13.75lbs ea
Douglas Ultimate 9x9's 4lb ea
LTR 8" rears 3.5lbs ea
8x9 Hipers dual beadlocks integrated hubs 6.5 ea
00chevy
May 11 2007, 10:29 AM
Yeah, My 21x12x8 7 paddle extremes(bead to bead buff) on 8x7 .125's weigh alot less than 13 pounds.
Chuck's 06 450
May 11 2007, 11:54 AM
updated again today
Sandstorm
May 13 2007, 05:25 PM
QUOTE(Chuck @ May 11 2007, 12:54 PM) [snapback]368717[/snapback]
updated again today
I reweighed my 20x11x8 8paddle Sand Devils on .160's I put 13.75ea but they are 13.00lbs ea....
450RRR
Jun 19 2007, 11:15 AM
my daughter runs that exact same setup.....I guess I should go weigh them.....
TRiXe
Jul 20 2007, 03:59 PM
QUOTE(Chuck's 06 450 @ Feb 11 2007, 05:57 PM)
Do know how many pounds of air that is in these tires or is this dry weight???
450RRR
Aug 25 2007, 02:51 PM
QUOTE(TRiXe @ Jul 20 2007, 01:59 PM)
You do realize that "pounds of air" as measured in Pounds Per Square Inch (PSI) has almost no bearing on the actual weight of the tire....
but realistically...one could assume roughly 5psi in most of these tires......
1fast450
Aug 25 2007, 04:34 PM
i know this is for paddle tires but does anyone have the weights of 20" razor2 rears on stock wheels compared to stock wheels and tires?
jcf1977
Sep 16 2007, 11:39 AM
Good info, thanks............
jwilson84
Sep 16 2007, 12:35 PM
what about 20/11/10 or 20/11/8 itp sand stars
I guess I could unmount n weigh...lol
but would rather not
thanks
00chevy
Sep 16 2007, 02:09 PM
What about 22" Skat-Trak Superlights?
GPracer2500
Sep 16 2007, 10:57 PM
These were all weighed on a digital postal scale (at my post office!):
8 Pad STU Sand Skate II, 20x11x10, 10x9 3+6 .125
15lbs 7oz
8 Pad Hauler Extreme std. buff 20x10x10, 10x9 3+6 DWT Red .190
16lbs 14oz
8 Pad Sand Sharks 20x11x10, 10x9 3+6 DWT Black .160
17lbs 11oz
Dune Tracker front 21x8x10, 10x6 2+4 DWT Black .160
12lbs 12oz
6 Pad Haulers std buff 20x10x8, 8x8 DWT Red .190
14lbs 13oz
8 Pad Gliders std. buff 21x12x8 (significant wear), 8x8 .125
12lbs 2oz
Cheng Shin Dune Slider 21x12x8, 8x8 .125
17lbs 10oz
sredish
Sep 17 2007, 08:57 AM
QUOTE(Chuck's 06 450 @ Feb 11 2007, 06:57 PM)
you just can't beat em.....
Markflexes
Nov 6 2007, 12:29 PM
22x11x8 8 paddle Haulers (std buff) on 8x8 Douglas Blue Labels w 5# psi = 14#.
I have ordered a new set. 21x12x8 8 paddle Haulers (double buff, bead to bead) on 8x7 Douglas Blue Labels. Should be in any day. I will weigh them and post when they arrive.
Great thread and info. Thanks.
bueller
Nov 6 2007, 03:04 PM
Just weighed these on a digital postal scale.
22x11x8 7 paddle glider standard buff on douglas 8x8 .160 wheels = 12# 3 oz.
Chuck's 06 450
Nov 6 2007, 05:16 PM
updated today
Markflexes
Nov 14 2007, 10:33 AM
21x12x8 btb buff 8 paddle Haulers (5# air) on Douglas Blue Labels = 12#
jwilson84
Sep 10 2008, 05:03 PM
If some1 wants too add them, i just picked up a set of 21x12x8 7 paddle hauler superlites on 8x7 .125 wheels and they weigh 12.5 lbs each
atcmaniac
Nov 18 2008, 05:10 PM
QUOTE(sredish @ Sep 17 2007, 08:57 AM)
your supposed to use an 8x10 wheel with that tire for it to perform the best. thats what fullerton sand tires told me.
r450er
Nov 18 2008, 06:59 PM
QUOTE(atcmaniac @ Nov 18 2008, 06:10 PM)
No..8x8 is good, 8x7 probably better.. You want the tire to balloon out and kinda float on the sand.
atcmaniac
Nov 19 2008, 12:12 AM
QUOTE(r450er @ Nov 18 2008, 06:59 PM)
being 21x12 its already like a balloon. you dont put a 12inch wide tire on a 7inch wide rim. that will make it skinny looking
h0nda450mainiac
Nov 19 2008, 12:14 AM
who cares about tire look it's about performance ALOT of pppl have 10tire on 8 and 6 inch rims
atcmaniac
Nov 19 2008, 01:06 AM
QUOTE(h0nda450mainiac @ Nov 19 2008, 12:14 AM)
we are talking about a 12inch wide tire. and i have a set of padla brats and they are on a 10inch wide rims. it will not perform the same on a 7inch rim.
h0nda450mainiac
Nov 19 2008, 11:12 AM
why would you want such a wide tire???/
so you can turn slide is all i can think of ?? and i can spin in a perfect doughnut with 22x8x8
hawk-trx
Nov 19 2008, 11:29 AM
a wide tire has more paddle in contack with the sand so it gives better traction. and traction is the whole point od a paddle tire.
if fullerton's is selling them on 10" wheels he mush have changed his thinking. in the past fullerton's has always recomended 8x8, my buddy got 9's because he was out of 8's.
wolfpack
Nov 19 2008, 11:35 AM
I run my 21 12 8 8 paddle haulers on 8x7 rims... Works good IMO.
h0nda450mainiac
Nov 19 2008, 11:38 AM
QUOTE(hawk-trx @ Nov 19 2008, 11:29 AM)
so your saying 20x10x10 has more traction than 22x8x8?????/ width isn't the only determining factor for traction
hawk-trx
Nov 20 2008, 04:01 PM
yes i would. an 8" wide tire would dig a trench unless ran with 1-2# pressure. the 10 wide tire would have a wider foot print, but i dont really like you example cause you are compairing apples and oranges.
a 21-12-8 would give more traction then a 21-10-8
if you took the same tire and ran it at 3# then ran it at 15# which do you think would hook up better?
broncbob
Mar 12 2009, 03:36 PM
I may be way off on my paddle tie thinking, but here is my thoughts.....
The smaller the wheel size is from the tire width, the taller the tire gets as well as narrowing up. You can use this to help you in many ways, say you can't quite pull a paddle count, you may be able to use a wheel that is smaller to take some of the bite out of the tire and make it work for you. It also works the other way as well, the wider wheel will cause the paddles to see more sand contact, thus hooking better. Air pressure has to do with it as well.
boostin
Oct 2 2009, 12:05 PM
22x11x8 8 pdl extreme triple buff,8x8 .125 rim, 11lb-9oz
Boxcar (coosbay. OR)
Oct 19 2009, 03:41 AM
QUOTE(hawk-trx @ Nov 20 2008, 04:01 PM)
I Don`t know what you run your paddles in, a smaller wheel like a few others that know whats up have said makes your tire ballon up witch helps it dig to the wetter sand where the real traction is in the sand, for draging and hill shotting anyway.
Oct 19 2009, 03:43 AM
QUOTE(wolfpack @ Nov 19 2008, 11:35 AM)
Yes it does thats a dune lauching settup there.
