QUOTE(DMAC450ER @ Jan 7 2007, 06:57 PM) [snapback]323483[/snapback]
revving will cause the front to go up. Rear break will make the front go down but make sure you pull in the clutch so you dont stall out in the air. I'm not sure butt the front brakes should do the same thing as the back, i'm going to have to try it.
front brakes dont do a whole lot in the air.... grab some rear break and your in business
