QUOTE(TopGunnYFZ450 @ Aug 23 2006, 11:07 PM)
QUOTE(Mitco39 @ Aug 23 2006, 11:19 PM)
My guess is your master cyclinder is shot...
My cuz's Z front brakes work just as good as mine...good enough to do stoppies or endows or w.e you wanna call em...
Make sure your not leaking any fluid onto the brakes.
Can you pull the brakes all the way to the bars? You should not be able to...Atleast everything i have ridden gets very stiff and unless you hold it for a period of time you will not get the handle to touch the bars.
[right][snapback]273763[/snapback][/right]
I agree, my cousins Z has great brakes he is always flipping over forwards
I dont think brake lines will get you what your looking for, i would look into the master cylinder
[right][snapback]273841[/snapback][/right]
what he said is true, when i tore apart my bike to get it gusseted and PC'ed, the rear brakes sat for about a month. When we went to put it back together it had no rear brakes. You could push the lever all the way down. We had to bleed and bleed them and finnaly just replaced the cylinder, i dont know what went wrong. But they are good now
Eric.
