Full Version: A picture is worth a 1000 RPM
Honda TRX450R Forums: Honda TRX 450R Forum > TRX450R.ORG Sponsors - If you are interested in becoming a supporting vendor, please email sales@atv.com > Rossier Engineering
Pages: 1, 2
JOE@Rossier
Green wire mod bumping your rev limiter from 9800 to 10700. remember to heat shrink both ends when your done. I have had a lot of calls on this topic
Chuck's 06 450
Do you know if it changes the ignition curve or is it just a rev limit change? Just curious - thought everyone would like to know.
leviredneck59
is everything in the same place on the 05-06 when it comes to the cdi???
also what year is the R in that pic???
ttracer65
this mod is only for the '06 model.
sredish
and its rev limit only, not a different curve.
Jonathan Shaff
this is for the 06 only
sredish
QUOTE(Jonathan Shaff @ Aug 15 2006, 05:03 PM)
[right][snapback]270578[/snapback][/right]
Blackie
QUOTE(leviredneck59 @ Aug 15 2006, 04:38 PM)
[right][snapback]270538[/snapback][/right]
leviredneck59,
I believe you are the owner of a brandy new 07 correct?
I would assume this trick works on the 07, but definately wait for a confirmation from a better source before snipping wires.
I'm sure the one in Joe's pic is an 06.........
Nice Idea Joe........
MrBullDawg
QUOTE(sredish @ Aug 15 2006, 03:00 PM)
[right][snapback]270576[/snapback][/right]
Are you sure of this?
It seems on mine (could just all be in my head) that it has more power with the wire cut. I put a switch in mine and with the wire "cut" it pulls harder and I tend to get the front end up more often when I take off. I also do better in drags smile.gif
leviredneck59
2006BLACKTRX450R
ya mine's an 07, but honda didn't change anything from the 06-07 except for the rear travel
Ripper
QUOTE(sredish @ Aug 15 2006, 07:25 PM)
[right][snapback]270580[/snapback][/right]
............................user posted image.................................
-------- Now that's some funny chit!---------
JC-TRX250R
So has any determined if it just increases the rev limit or does it also change the timing curve?
sandshots
anything similar that can be done to the 05? I'd like to save the 200.00 bux it would cost to get a dynatek.....
Blktegra
nope there is no magic wire to snip on the 05 to increase the rev limit
TLONG
so this can be done with the 07 model also?
808racer
well I went to take a look under the hood of my 06 and found that my wire has already been cut and nicely put away deen in the CDI.
I guess my Honda dealership knows about this little trick and did it for me already! bleh.gif
but yes, I just wanted to maybe help conferm that this is an actual trick
lotsogas
What goes through this wire and such? I'm gonna try to see if I can trace the same wire on my 05 and see if I can get it to work.
Dan
Gumby46
Shouldnt the title of this post be "A picture is worth a 1,000 RPM!" hehe
leviredneck59
Lotsogas,
This trick will NOT work on the 05!!!
Don't try it, you'll screw up your 4 wheeler!
JOE@Rossier
Thats a yes for the 07 models
Thats a BIg no for the 04-05 models
leviredneck59
Will this allow the engine to rev past its red-line, shortening the life of the motor?
JOE@Rossier
More RPM's, compression, and stout cam profiles( other than drop in) will require more maintainance over stock period.
leviredneck59
alright thanx
Slimsride
um...i'm slightly retarded here...um..okay alot retarded...
so you snip the green wire...heat shrink the ends.......then what..thats it??no more work to do? snip and go?
just a wee bit tooo easy there?
besides what the hell am i looking at in the picture anyhow..I'M LOST
JOE@Rossier
The green wire you need to clip to up your rev limit.
FLC502R
QUOTE(Slimsride @ Nov 8 2006, 02:21 PM)
[right][snapback]301930[/snapback][/right]
That is your cdi box under your hood
Crwcompact
Yes it can be done on the 07'
So do it,,,,everyone else is.
onehandbandit
Instead of just cutting the green wire.Would it be better to put a male end and a female end on the other one.So if you wanted to put it back the way the Honda had it you could.This way you can get the best of both worlds.Us the RPM when you race and go back the way when you are trail riding.That's just my out look on it.Thanks.
hillbilly
QUOTE(onehandbandit @ Mar 20 2007, 10:22 PM) [snapback]352514[/snapback]
yur kidding right?
Cumminsman76
Take the plug apart and pull the wire out. Then if you need to have work done or sell it you can put it back together. Theres a simalar wire on 03 Dodge rams Hemis. From now on if I buy something with a green wire I'm cutting it.
IMSROLL450R
QUOTE(Cumminsman76 @ Mar 23 2007, 08:03 PM) [snapback]353669[/snapback]
haha thats funny i would too.
So if i have the HRC kit which already adds 1000rpm will this do any good?????? Sorry for the late question but that just occured to me.
MDFMac
no doing the HRC kit and the wire will not do any thing diffrent..
yes you can do it to a 07
IMSROLL450R
QUOTE(MDFMac @ Apr 10 2007, 06:12 PM) [snapback]358894[/snapback]
thanks man thats what i figured
mccown450
i clipped the wire on mine, then when my R got thrown off the trailer and i took it to the dealer to get it all fixed, they soldered it back together and put heat shrink on it. i got to looking and found that you can pull the wire out of the harness. i did that and i can pop it back in no problem. i was thinking of running a switch up to my bars so i could switch between the stock rev limiter and modded rev limiter, but i dont want to cut the wire again.
twilhelm
QUOTE(JOE@Rossier @ Aug 15 2006, 12:26 PM) *
I am the slow one here, what do you eman by heat shrink both ends? How do you do this? Thanks for the insight and the free performance mod.
bueller
QUOTE(twilhelm @ Dec 4 2007, 10:08 AM) *
Go to your nearest hardware store or home depot and go to the electrical dept. and ask for heat shrink. Buy a small size that will fit over each end of the cut wire. Cut a piece about two inches long and leave about an inch sticking out beyond the wire. Take a match or lighter and run it under the heat shrink and it will instantly begin to tighten over the wire. This is just to prevent a short if the wire to touch anything when bouncing around under the hood. Do this separately for each cut end of the wire.
twilhelm
QUOTE(bueller @ Dec 4 2007, 10:35 PM) *
Thanks, much appreciated !!
cnewt14
sorry for the question but how would you add a swith to this? so you could cycle between the two?? i know aboslutely nothing about switches but i can solder. thanks in advance
mccown450
QUOTE(cnewt14 @ Jan 28 2008, 12:11 AM) *
cut the wire in half, wire a simple 2 way switch between it. that way it's an inline switch and it's all good. i still haven't done it though
vade450
Can't u just go the other route and just buy the 12 dollar hrc harness?
Flyin450R
Just cut the wire, heat shrink and leave it alone.
dragfreek
i know im beating a dead horse but will it work on a o8 i know they changed a few things so just checking
papasss
banghead.gif The 07 looks the same?? as that Picture.... or that is a "07" their's 2 much green wires???????Click to view attachmentClick to view attachment
JOE@Rossier
ttt
542 ice cube
will this mod work on the 08s? any other inexpensive mods for them?? thanks in advance
KillerQuad
QUOTE(542 ice cube @ Nov 5 2008, 12:16 AM) *
542 ice cube
sweet deal. thanks
B4A5R0T
im gonna do that to mine asap just have to get a nice switch and place it under the seat
is there anything that might happen if i switch in between those 2 settings while the quad is running???
Mac_in_SD
Can someone repost or send me the picture of how to do the mod on the first post. All I see is the sexy blue "X". Thanks.
vcforlife15
ill grab a picture for you in a hour or 2
