Full Version: Look what showed up on my doorstep
AL Elks
user posted image
Wouldn't you know it. My LTR is in for the frame recall. I'm hoping it's done by noon tomorrow.
Thanks goes out to Matt at Bare Performance for signing up to be a Distributor for this item. You won't find a cheaper place to buy it anywhere on the net either.
Thanks Matt!
AL Elks
Just a heads up. I did not notice this but I need a couple more things to make this particular kit work.
I didn't do enough research. I thought the $589 kit had everything I needed. There are 2 items this kit does not have. The RPM Converter cable and the inductive pickup cable shown below are what's needed. Looks like I'll be spending a little more money ($120). Get ready Matt! Of course I might be able to find the inductive pickup locally.
http://www.innovatemotorsports.com/xcart/c...productid=16144
http://www.innovatemotorsports.com/xcart/c...&cat=250&page=3
558KingR
Dang Al, i might have to rent that thing from you!! I may have to remortgage the house to purchase that bad boy lol.gif
AL Elks
Well I Finally got a chance to get out and do some tuning the other day so I snapped a few pictures while I was at it.
This is the setup I am using right now. It consists of the LM-1 Box, the RPM converter, the Wideband Oxygen sensor, the RPM Inductive clamp and of course I have a 12v power supply that I’m using so I don’t have to tap into the battery on the bike. The only thing not hooked up is the TPS wire. I’ll update this topic when I get it hooked up.
Here’s a picture of the whole setup:
user posted image
Here’s a picture of everything hooked to the bike and all the extra wires and battery in a backpack. I tried using a very small 12v battery but it did not have enough amperage to operate the LM-1 and the Oxygen Sensor.
user posted image
Here’s another picture from the side showing the RPM inductive clamp clamped to the coil wire:
user posted image
Another picture from the side showing the Oxygen Sensor lead and the RPM inductive clamp lead hookups.
user posted image
Now here’s a picture of how the FIMAK hooks to the bike to tune it:
user posted image
Picture of the FIMAK in “Active Mode” which is real time. In other words it shows the RPM, TPS and % of fuel increase or decrease as you give it more throttle.
user posted image
Picture of the FIMAK in “Diagnostic Mode”:
user posted image
Picture of the FIMAK in “Manual Mode”. This is the mode used to program each point on the MAP.
user posted image
Picture of the FIMAK in “Block Edit Mode”. This mode is used to change multiple ranges at once.
user posted image
And here are my results after tuning for WOT and shooting for an AFR of 13.1:1. I still have just a little tweaking to do. I was hoping that 1% fuel increase would equate to a constant change in AFR but that’s not the case.
user posted image
EDIT: I just installed the Trinity intake and modded my airbox for better flow and it barely even changed the AFR. Seems that there is some adjusting going on which I thought the system couldn't do.
