Im not sure why you think 2 stroke quads dont idle with pipes Hondachick21, but i have owned many, many honda 250r's and damn near all of them idled.
First, if you want to check for air leaks, get yourself a can of ether (quick start spray) and while the engine is running, spray it around the base of the cylinder, all around the cylinder head,in between the case halves, the intake mainifold (both front and back around just the manifold side of the carb). If the rpms suddenly increase theres your air leak.
Now, if there is no air leak, perhaps your old worn out carb is the culpret. You can try to clean it and tune it, but if all that fails its time to buy yourself a new Kiehn pwk series carb. 39mm suites the 250's and the 500.
Idle has alot to do with the pilot jet on those carbs.
I personally think Mikuni carbs suck, which is what suzuki used. Buy a keihn and i bet you will like it ALOT more
