Full Version: Free 1000rpm on '06
retired banshee
I stole the topic from exriders but thought I would share the trick over here. The '06 hrc "sub harness, cdi" as they call it simply eliminates one of the four wires on the plug.
So for all of you '06 owners you can just cut/remove that wire and gain 1000rpm plus a different timing curve. I suggested that you run the wire through a switch so you could toggle the two curves. Perhaps mount it on the bars and have on the fly tunability? post-696-1105671076.gif
86atc250r
Moves to the Engine FAQ -- Thanks!
snowormud
is this just for the 06 or will it work on the 04-05?
Trx450always
just for the 06
Ripping R
QUOTE(Trx450always @ Oct 18 2005, 06:44 PM)
just for the 06
[right][snapback]148395[/snapback][/right]
z-dan
I was reading some threads on Thumpertalk and read about the mod that they do on the CRF450x it is very similar to this................Just goes to show how similar this engine is to the CRF450x in fact I think its the same engine.
In the CRF world its calle the PINK Wire mod.
PINK Wire Mod
This is the page I got pics from:
pink wire thread
also do a search on crfsonly.com or thumpertalk on the pink wire mod and you will find a ton of info.
CANT WAIT to do mine!!!!!!!!!!!!!!!1 biggrin.gif biggrin.gif biggrin.gif biggrin.gif
spoRtRax450R
yeah we kinda got the shaft, but i dont see any more hp in the long run, just a different way of delivering it
Byron
Us 04/05 owners don't need a fancy "sub harness" gizmo to get more power. We already have pleanty! bleh.gif
retired banshee
For the record. The wire to disconnect is the green one on the four pin connector. I would try to un-pin it from the plug so you don't have to cut it (if you don't have the hrc harness).
Brad
QUOTE(retired banshee @ Oct 19 2005, 10:04 PM)
[right][snapback]148957[/snapback][/right]
To depin that plug, you need to remove the yellow lock. Carefully pry the lock out with a screwdriver. Once that lock is out of the way, you will see a black tab. Lift that tab away from the pin, and the pin should be able to freely slide out of the back of the connector.
DanW
[right][snapback]149090[/snapback][/right]
[/quote]
Can you tell us what unhooking the green wire really does? Just raise the rev limit up 1000 rpms, or change the timing curve also? If it changes the curve, what does it change it too?
Brad
[quote=letitsnow,Oct 26 2005, 04:52 PM]
[/quote]
[right][snapback]151417[/snapback][/right]
[/quote]
Haven't tested a stock 06 box yet
hondait
banghead.gif [COLOR=red] Hey, I'm a new guy to this bad- ass site, Could someone explane what disconecting the grean wire will do to the power curve, I have a black 06 ER. Thanks for the info....... James
retired banshee
QUOTE(***HRC MANUAL***)
Installation of the ICM sub-harness allows the engine to rev 1,000 rpm higher than standard.  This modification provides a different ignition advance curve designed to compliment the other components of the kit
[right][snapback]157594[/snapback][/right]
DanW
QUOTE(hondait @ Nov 11 2005, 12:35 PM)
They also say that the '05 only revs to 7500 rpms......
rwhitley
so you just unhook the green wire and leave it like that? or do you hook it up somewhere else? Once you unhook it, you just leave it danglin?
The swede
QUOTE(retired banshee @ Oct 19 2005, 02:02 AM)
[right][snapback]148372[/snapback][/right]
The swede
Hello
Im kind of new tho this site but i like it alote (wish we have something like this in sweden)
Now my question is aboute the green wire on the 06 (to gain 1000rpm)where is it located,does some one have a picture so i snap the rigth one,
Please forgive my spelling long time since school.
remmy
I snagged this picture from another website....
I have not done this mod yet, but it is the plug on the left - the only one with 4 wires.... I wouldn't recommend just cutting it the way it is shown....
Good luck!
user posted image
McCune
QUOTE(remmy @ Feb 15 2006, 08:49 AM)
I I wouldn't recommend just cutting it the way it is shown....
Good luck!
user posted image
[right][snapback]196826[/snapback][/right]
Why not?? What could go wrong ?
Trx450always
short out. you can pull the wire out of the harness and make it cleaner.
Tripyn
Good Stuff Remmy, I will tuck that away and get it done if I ever get my bike back!
Brad
Cutting the green wire adds a good bit more timing in the mid-high RPM, in addition to the increased rev limit.
sredish
QUOTE(Brad @ Mar 23 2006, 11:31 AM)
[right][snapback]214357[/snapback][/right]
as well as taking money out of your company's pocket....
trx450r1
Makes me wonder what our full CRF setup actually revs to. I've got a milk carton full of wiring, connectors, lights and all the other stuff that comes off with the conversion.
One thing is for certain, it's stupid fast!
quadking450r
What happens when you get a rev box to place that???
808racer
wow, this is a cool find!
can anybody help me and post some step by step pics or explain more because I opened up my hood today after seeing this top and......... well there were a buttload of green wires on the left side. post-696-1105671032.gif sorry if this is noobish but I just picked the bike up this weekend and this would be a great help to the HRC....
P.S. DAMN THE HOOD IS EASY AS HELL TO TAKE OFF, I thought it was gonna be some of those tab things like on the 400ex but hell, I just pulled the thing off no_bashing1.gif
Tripyn
If I remeber right it is the connector all the way to the left if you are standing right over the hood. I clipped the green wire and used heat shrink over it so I would not have to worry about shorting it out. I can take a pic of mine tonight if that helps.
