When you get the Ring gap you want on both the comp. ring and the oil rings then you will be ready to put the rings on the piston.... Be sure to NOT LINE THE RING GAPS UP....
(Talk about burning oil....
) (i like to go at 12 o'clock, 6 o'clock, 3 and 9 )
I use Honda GN4 non moly oil for the Install of everything.... I use Honda 2 stroke oil for the ring install and to lube the Cylinder wall down with...
Install one of the Piston Wrist pin circlips in the piston....
Then put the piston on the ROD and install the Wrist Pin.... then you can put the second circlip in (i used a LONG flat head screw driver and used the Clutch Cable as a Prying piece....
MAKE SURE THE SMALL RELIEFS FOR THE EXHAUST SIDE ARE ON THE EXHAUST SIDE OF THE ENGINE....
Also make sure you put a rag in the HOLES of the engine.... so if you drop the clip it doesnt fall into the engine....
<<< MAKES FOR A BAD NIGHT.....
