BREAKING NEWS-->
After already have this typed up and a long shpeal about this and that and then the Web site CRASHING on me... i am just gonna do it all again....
HERE GOES....
CP pistons Formula is --> .0045 per cylinder INCH + .004.... that is where the .020 and .021 come from.... That was actually a Very highly recommended gap by many builders i talked too...
The 2 ring piston as the HH is (1 compression ring) may be pushed a little closer...
I have talked to 3 engine builders on the phone and 2 here in my local area.... they all said that the .0045 per inch is pretty tight STILL... so the recommend the +.004 at the end as CP does or to go with .005 per inch or .0055 per inch.... .0055 is REALLY BIG.... They said the .005 per inch was the best STRIGHT FORWARD Formula to go with....
so the Formula for these 2 sizes of pistons will be....
94mm (3.70") * .005" = .0185" of gap (<< No less than ) (.020 is recommended)
97mm (3.82") * .005" = .0191" of gap (<< No less than ) (.021 is recommended)The 2 NO LESS Than numbers where only recommended because of the fact that the pistons in question are 2 ringers....
The .020 and .021 of gap is a Safe bet.... this will have no problems keeping your Cylinder safe from the GOUGING effect of Tight Rings.... and the Bigger the gap the longer the Ring life... To a certain point where it will start to loose compression...
OIL Rail GAPs -->
.015 MIN. on the Oil Rails
(could be .030 but .015 is MIN)For the People who are Boreing their cylinder to the 480 or haveing one redone for the stock bores... the Tolerance is .
001 and
.0015The pistons where made by CP with a Tolerance of .000001 of an inch....
.. is that possible...
... WOW... Mad Props for PRECISION....
This is all up for debate by people that have thier own numbers but these are the numbers that we found to be SOLID BUILDERS NUMBERS......
