Welcome Guest ( Log In | Register )
ATV Dealers -  Honda ATV -  Honda ATV Specs -  ATV Classifieds -  ATV Insurance
Closed TopicStart new topic
> Jetting, How to fine tune
Ticeman
post Jan 13 2005, 09:02 AM
Post #1
Yamaha idolizes ME
Group: Blue Riders
Occasionally there are questions that present themselves from natural causes, mostly due to differences in machine set-up. Since I am leaving Hot Cams, the guy that will be answering the tech questions here asked me to do a Faq Page on jetting. I'll post it here and you guys can tear it apart or add to it or tell me what you think.
Generally speaking, jetting can be quickly diagnosed by the following questions:
1) Low end performance
A) A lean condition is typified by surging and popping back thru the carb when steady light throttle is applied. It will cause popping during high rpm deceleration thru the exhaust (quicker when moderately lean, rapid when very lean, once every now and then when correct), once the rpm has dropped enough that the air speed thru the idle circuit is slow enough for it to pick fuel up that is. It can be quickly diagnosed by adding a slight application of the choke or starter enricher (if the popping stops, it’s lean). The intake will have a “droning” sound at steady throttle or under light acceleration loads in low gears when it is too lean. So, the question is; “Does it pop out the exhaust during deceleration with a closed throttle from high rpm to idle, while in 4th gear or above?”
B) A rich condition can also cause surging but will more than likely be very sluggish to respond to throttle inputs too. A quick diagnosis is to run the machine up to high rpm and listen for the occasional (once every now and then) pop out the exhaust, if no popping is heard, it is too rich on the idle circuit or fuel screw. If turning the fuel screw in does not remedy the richness, take a step down on the pilot jet and try again. So, the question is; “Does it pop out the exhaust during deceleration with a closed throttle from high rpm to idle, while in 4th gear or above?”
2) Midrange performance
A) A lean condition in the midrange is somewhat hard to diagnose. The biggest single giveaway is the sound of the engine. Usually when the engine is lean in the mid, it stutters and stammers and just doesn’t want to run right when it is VERY lean. When it is a little lean, it will cause the engine to labor slightly to run (it won’t sound happy), the engine will sound strained to maintain rpm, and the droning sound from above is easily heard thru the intake. It will also most certainly have a hesitation during sudden throttle application. This triggers a sound to be generated from the carb like the engine is sucking for air right before the engine starts to accelerate. A light popping will also be heard from the exhaust during steady throttle. When the jetting in the midrange is correct, you can accelerate thru the midrange with light throttle application or rapid throttle application and no hiccup or hesitation will be felt or heard. A method of diagnosis for a lean hesitator is to pull the choke on just for an instant and then stab the throttle the instant the choke is closed. If it takes off, the needle may be too lean or the pilot jet too small. Start with the needle, by lowering the clip one notch and feeling for the result. So, the question is; “Does the machine accelerate slowly through the midrange without any hesitation or hiccups?” Listen to what he says closely and go from there.
B) Rich conditions in the midrange are easy to diagnose. Under normal circumstances, a richly jetted midrange will make the machine very slow revving and unresponsive to small throttle position changes. If it’s the size of the pilot jet causing it, you will get no popping during deceleration no matter where the fuel screw is set. If it’s the needle causing it, you will be able to get it to pop during decel by adjusting the fuel screw. So, the questions to ask are: “Does it pop out the exhaust during deceleration with a closed throttle from high rpm to idle, while in 4th gear or above?” And “Does the engine react instantly with acceleration to small throttle changes when applying the throttle lightly?” (works best when in 2nd gear so the throttle changes can be felt immediately). If those 2 questions are answered with “No” and “No”, it’s most likely rich on the pilot circuit first, one step down on pilot jet size then repeat the test. If the answers change to “Yes” and “No”, lower the needle (raise the clip one position). Keep changing until you run out of clip positions. If it’s still needle rich, go to a leaner needle.
3) Top end performance
A) Lean condition on top is a little harder than the midrange. If it’s VERY lean, it just won’t take throttle. If it’s a little lean it will most likely rev quite good but, may SEEM to struggle to rev all the way out. Typically speaking, in a 4 stroke, it’s pretty hard to discern the differences from a little lean, just right, and a little rich. About the only way is to learn how to read spark plugs or find a lambda sensor to use. The question to ask is; “Will it take throttle past 1/2 throttle to ¾ throttle?” If the answer is “No”, it’s lean.
B) Rich conditions are fairly easy to discern. If it won’t accelerate or accelerates very slowly between ¾ throttle and WOT it’s rich. The question is obvious.
Tony
Hi ho. Hi ho. It's off to work we go.........
You can drink an ugly girl pretty but you can't drink a fat girl thin...........Jeff Daniels
You can fix ugly but, you can't fix stupid...............Ron White
Go to the top of the page
+Quote Post
mixxer
post Jan 13 2005, 09:30 AM
Post #2
Peter PumpkinHead
Group: Sponsor
very nice but i say "screw the new guy"
if he knew enough to fill your shoes, he wouldn't need the help would he? no tice, no dice!
shame on hotcams for letting you slip out their door! (IMG:http://www.trx450r.org/forum/style_emoticons/default/angry.gif)
i would just post the owner of hotcams cell phone number and say it's a 24/7 jetting hot line :D (IMG:http://www.trx450r.org/forum/style_emoticons/default/tongue.gif) yeah, that's the ticket!
Venom Performance of Michigan\ 517 655-2870
KBR \ Kyle Baldwin Racing of Utah \ 801 967-7100
Hansen Performance of Idaho \ 208 313-5282
....learn to have some patience??!!......how long is THAT going to take??!!!
+Quote Post
ctx97
post Jan 13 2005, 09:40 AM
Post #3
Group: Members
good post, I'll be using this shortly :)
05 Black 450R
UNI Filter
AC Stadium Front Bumper
Power Madd Black/Silver HandGuards
Pulse Charger
Vented Airbox Lid
Hot Cams Stage II
HH 13.75:1
Work's Tripple Rate With RR Up Front
Derisi Rear
MX GTT Link
+Quote Post
Bad Habit
post Jan 13 2005, 09:53 AM
Post #4
The Diet Coke of Evil
Group: Members
I don't claim to have .001% of the knowledge that you do Tony, but something that might be added.
Maybe a comment about rich on top can emulate a false rev limit. I've seen many people that think they are simply hitting the rev limiter and their reasoning for hitting it so quickly is due to their brand new whiz bang exhaust allowing it to rev quicker. With the new exhaust and the unavoidable increase in exhaust db, they are not realizing that it's not turning near the rpm to be hitting the ignition limiter.
Is this going to be for HotCams internal use, kind of a script for the troubleshooting guys to use? If so, I will default back to John's answer. (IMG:http://www.trx450r.org/forum/style_emoticons/default/tongue.gif)
Dan
'05 450R - lot's of stuff
'02 400EX - see above
'02 90Kasea - "Blue Dragon"
'06 90Kasea - flower stickers
'70 Dude - lot's of miles but still runs
'70 Blonde - handles great but requires lot's of upkeep
'95 Lil Man - reliable and predictable
'96 Chic - loud and uncontrollable
+Quote Post
Ticeman
post Jan 13 2005, 02:24 PM
Post #5
Yamaha idolizes ME
Group: Blue Riders
Yeah, it's to help the FNG. That means Fun New Guy. :D
I did't want to leave them in the way it's happening. They relied on me heavily for a lot of information and this is some of it. If it would have been a bad parting, I'd have said screw it but, it isn't and I won't.
That's a good point, BH. It can also be caused by lean jetting at near std rpm rev limiter levels (around 10000 it will do this with lean jetting on a YFZ and my YSR too). I thought about that too then decided to do it this way.
Tony
+Quote Post
Bad Habit
post Jan 13 2005, 02:29 PM
Post #6
Group: Members
QUOTE(Ticeman @ Jan 13 2005, 01:24 PM)
Ummm, I didn't know that was the what that meant. (IMG:http://www.trx450r.org/forum/style_emoticons/default/unsure.gif)
NG = New Guy, but I coulda swore that F = something else. (IMG:http://www.trx450r.org/forum/style_emoticons/default/o.gif)
Dan
+Quote Post
KBR
post Jan 13 2005, 03:43 PM
Post #7
Group: Members
Tony, thats very informative, I am printing, laminating and inserting in my tool box!
BTW.....I just got my Hot Cams shim kit, what a lifesaver that was.....
THANKS!
+Quote Post
Ticeman
post Jan 13 2005, 04:06 PM
Post #8
Yamaha idolizes ME
Group: Blue Riders
QUOTE(Bad Habit @ Jan 13 2005, 02:29 PM)
Yeah, whatever. :blush:
Tony
+Quote Post
Ticeman
post Jan 13 2005, 04:08 PM
Post #9
Yamaha idolizes ME
Group: Blue Riders
QUOTE(KGB @ Jan 13 2005, 03:43 PM)
THANKS!
It IS a nice kit for what you spend!!! Really a good deal.
Tony
+Quote Post
the_hulkamaniac
post Jan 13 2005, 04:33 PM
Post #10
Part time genius.
Group: Members
I got the kit as well along with the degree wheel. The wheel is huge BTW. Now I just have to learn how to use it, the fun part.
Thanks for the info Tice. Sticky or FAQ please!
"I reject your reality, and subsitute my own." -Adam Savage
"It's true... I'm a rageaholic! I just can't live without rageahol!" -- Homer Simpson
Jesus, save me from your follower's.
Just fell of the turnip truck.
The Simpsons have set a standard for us all to follow. I'll be damed if I don't follow that example!
I may not be a religous man... but you will be when I'm done with you!
"...the best thing would be to have a midget with a pocket full of cams that he can install in your quad for you to try out and decide which is best.... That would be far more useful than dyno runs."- Gabe 04
"Soon I discovered that this rock thing was true
Jerry lee lewis was the devil
Jesus was an architect previous to his career as a prophet
All of a sudden, I found myself in love with the world
So there was only one thing that I could do
Was ding a ding dang my dang a long ling long" -Ministry, Jesus built my hotrod.
"When we were thirsty for life, we drank vodka. When we were thirsty for water, we added ice." -Red Army Vodka
+Quote Post
SGVHONDA
post Aug 16 2006, 02:00 PM
Post #11
Group: Members
ticeman you gotta big brain seriously i'm printing that sh!t out!!!!!!!! :11doh:
+Quote Post
« Next Oldest · Engine Tech FAQ · Next Newest »
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 20th November 2009 - 04:46 PM
Explicit Dimness Skin By Invision Styles & Destiny Paradise
Privacy Statement
