Welcome Guest ( Log In | Register )
ATV Dealers -  Honda ATV -  Honda ATV Specs -  ATV Classifieds -  ATV Insurance
Reply to this topicStart new topic
> HRC Needle, May be a dumb question
AZ450R
post Oct 19 2006, 04:59 PM
Post #1
Group: Members
When they say put the needle on the third clip, does this mean the third clip from the top of the needle or from the bottom. Thanks for your guys help.
Go to the top of the page
+Quote Post
NHRAdragracer
post Oct 19 2006, 05:19 PM
Post #2
Proud member of the Flyin' Fat F-ers
Group: Supporting Member
I think the HRC needle on has 5 clip positions, so in this case it doesn't matter! :bleh: Sorry, couldn't resist, hehe.
But to answer your question, you count clip positions from the top of the needle (blunt end). i.e Clip position 2 will drop the needle farther into the jet than say clip position 4. :thumbsup:
2004 TRX530R 59.8hp/41.25 ft lbs
Venom Porting, Immortal Intake & +1 KW exh. valves, 99 mm 12:1 Wiseco 2-ringer piston, +4mm stroker crank, HC Stage 3 cam,
43.5mm Sredrum taper-bored FCR, Venom full exhaust, Modded ESR intake/ K&N, Dynatek prog. ignition, Trail Tech -4 flywheel
1955 Chevrolet Pro Streeter Big Block 468
1967 Oldsmobile 442 drag car Big Block 468
1969 Chevrolet Corvette 350c.i./350h.p.
1985 Harley Davidson Low Rider 80c.i.
2007 Chevy 2500HD Crew Cab Duramax
2008 Yamaha Raptor 815 Venom big bore stroker 76.35hp/61.8 ft lbs
2004 Honda 480R Venom big bore 58.5hp/38.6 ft lbs
How? no kids... uh wait, I mean 2 new little heathens that have seriously
impacted my toy fund!!! Watch out for my favorite future jockeys!!
+Quote Post
450RRR
post Oct 19 2006, 06:06 PM
Post #3
Uh Oh....it's the Po Po
Group: Mod Team
good question...... common misconception is when someone talks about raising/lowering the needle..... to raise the NEEDLE (richen) you need to LOWER the clip...and vice-versa.....
so what happens is this...someone may say "raise the needle one clip"... and instead of 'lowering' the clip on the needle to perform this task....they inadvertantly 'raise' the clip one notch....this of course will have a negative effect on the outcome....
raising the needle = lowering the clip = richer...
lowering the needle = raising the clip = leaner....
sorry....more useless info....Greg
86TRX250R (mostly stock 66mm bore x 72mm stroke)
86TRX250R (ESR310 72.5mm bore x 72mm stroke '298cc' fully modded) **for sale**
88TRX250R (ESR330 77mm bore x 74mm stroker '345cc' fully modded)
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
+Quote Post
AZ450R
post Oct 19 2006, 07:55 PM
Post #4
Group: Members
Appreciate the help, i just got in HRC kit minus the cam and am glad i can come here to get good answers, thanks guys
+Quote Post
450RRR
post Oct 20 2006, 08:43 AM
Post #5
Group: Mod Team
put the cam in......
no if's, and's, or butt's......
the stock cam is the weakest link in this machine.......that HRC cam will make your R come alive.... trust me.....
greg
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
+Quote Post
« Next Oldest · Engine · Next Newest »
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 20th November 2009 - 04:45 PM
Explicit Dimness Skin By Invision Styles & Destiny Paradise
Privacy Statement
