Oct 14 2006, 07:09 PM
Post
#1
Support the ASA!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Mod Team Posts: 5115 Joined: 23-November 04 From: Pismo Beach, CA Member No.: 928 |
TRX450R Online Reference Material Manuals, Links, Graphs, Diagrams, Utilities, etc.... The #1 Online Reference!!! _________________________ SERVICE MANUALS _________________________ Service Manual - Honda TRX450R - 04/05 31.5MB downloadable ZIP file. Store it on your computer to view and print from. http://www.bluezone.net.au/wheatbix/05trx450rSM.zip (Thanks wheatbix) Service Manual - Honda TRX450R - 06 85MB downloadable ZIP file. Store it on your computer to view and print from. http://files.filefront.com/06trx450rSMzip/...;/fileinfo.html (Thanks 06erDJ450) HRC Manual / Parts List - Honda TRX450R 2006 Photo scans of 2006 TRX450R Competition Kit Manual. http://www.trx450r.org/forum/index.php?sho...c=31716&hl= (Thanks nathan 89) Maintenance Guide - Honda TRX450R 2006 Honda Maintenance Guide http://www.trx450r.org/forum/index.php?showtopic=37188 (Thanks lumi & dirtdevil) Maintenance Guide Misc maintenance material from Honda for all years http://www.trx450r.org/forum/index.php?sho...c=37189&hl= (Thanks lumi & STEVE SJH) HRC Kit Manual - 2006/2007 2006/2007 HRC Kit Manual in PDF format. http://members.cox.net/riosluis/2006-2007%20HRC%20MANUAL.pdf (Thanks rioslu) _________________________ OEM PARTS CATALOGS _________________________ OEM Parts Catalog - Service Honda - 04/05 TRX450R Used for Reference - Great for printing whole catalog - PDF Format http://servicehonda.com/hard%20parts/atv/t...2004trx450r.pdf OEM Parts Pricing Page - Service Honda Used for pricing and purchasing OEM parts from Service Honda http://www.servicehonda.com/parts.php OEM Parts Finder / Fiche - Honda of Troy Used for Reference and Purchasing of OEM parts. http://www.yamahaoftroy.com/fiche_select.a...#FicheSelection (Thanks mstrav) OEM Parts Finder / Fiche - Planet Honda Used for Reference and Purchasing of OEM parts. http://www.planethondaracing.com/cgi-bin/hondaparts/parts/ OEM Parts Finder / Fiche - Honda of North Texas Used for Reference and Purchasing of OEM parts. http://www.hpnt.net/fiche_select.asp?vcc=A...#FicheSelection (Thanks sredish) OEM Parts Finder / Fiche - Motosport.com Used for Reference and Purchasing of OEM parts. http://www.motosport.com/offroad/oem.php?&nav=7 (Thanks Rob450R) _________________________ INSTALLATION AND MODIFICATION GUIDES _________________________ Uncorking your R on a budget Instructions for simple and cheap modifications, to get the most out of your stock TRX450R. http://www.trx450r.org/forum/index.php?showtopic=40841 (Thanks sredish) HRC Power Up Kit Installation Instructions for installing 04/05 Honda Racing Corporation Kit. http://www.rockinhorseweb.com/hrc_powerup_kit_install.htm (Thanks Rockin Horse) High Compression Piston Installation Instructions for installing aftermarket high compression piston. http://www.rockinhorseweb.com/Piston_Install_page1.htm (Thanks Rockin Horse) Engine Oil Change Instructions for changing your engine oil and filter. http://www.rockinhorseweb.com/motor_oil_ch...for_trx450r.htm (Thanks Rockin Horse) Transmission Oil Change Instructions for changing your transmission oil. http://www.rockinhorseweb.com/transmission...ge_for_trx4.htm (Thanks Rockin Horse) Factory Clutch Modification Instructions for removing the judder spring, seat, and engagement clutch disc. Helping with clutch disc life and more positive engagement. http://www.rockinhorseweb.com/Clutch_mod.htm (Thanks Rockin Horse) Cam Installation Instructions for installing aftermarket cam. http://www.rockinhorseweb.com/Cam_install.htm (Thanks Rockin Horse) Header Wrap Installation Instructions for applying insulating header wrap to your exhaust system. http://www.crfsonly.com/howto/header-wrap/...header-wrap.php Grip Removal Instructions Instructions for safely and effectively remove old grips from handlebars http://crfsonly.com/howto/grip-removal/grip-removal.php ESR Intake Modification Thread Instructions for modification of ESR Airbox Eliminator for better air flow. http://www.trx450r.org/forum/index.php?sho...c=28659&hl= (Thanks mixxer) 06/07 Headlight and Hood on an 04/05 Installation Thread Instructions for installing an 06/07 headlight and hood on an 04/05. http://www.trx450r.org/forum/index.php?sho...c=30342&hl= (Thanks mstrav & gumby46) Swingarm Installation Instructions for installing a Houser Swingarm, applies to most other swingarms as well. http://www.houser-racing.com/WSWrapper.jsp...uides/I0403.htm Steering Stem Installation Instructions for installing a Houser Steering Stem, applies to most other stems as well. http://www.houser-racing.com/WSWrapper.jsp...uides/I0406.htm Valve Adjustment - HOW TO Excellent step-by-step instructions for adjusting your TRX450R's valves. http://webpages.shepherd.edu/ghott01/valve...adjustment.html (Thanks ghott) Nor*Cal's TRX450R Tail Light Mod Excellent step-by-step instructions for relocating your rear tail light up to just below the rear fender. Creates a very clean look and also puts your rear light in a less vulnerable place. http://www.trx450r.org/forum/index.php?act...st&id=20320 (Thanks Nor*Cal) Caster Adjustment Instructions for Caster Adjustment. http://i42.photobucket.com/albums/e318/gum...rAdjustment.jpg Camber Adjustment Instructions for Camber Adjustment. http://i42.photobucket.com/albums/e318/gum...rAdjustment.jpg Toe-In Adjustment Instructions for Toe-In Adjustment. http://i42.photobucket.com/albums/e318/gum...nAdjustment.jpg Ball Joint Removal Instructions for Ball Joint Removal. http://i42.photobucket.com/albums/e318/gum...ointRemoval.jpg Pgreenlaw's Homemade Cam Tensioner Make your own cam chain tensioner tool. 06+ http://www.trx450r.org/forum/index.php?showtopic=49822 (Thanks Pgreenlaw) _________________________ CALCULATORS AND UTILITIES _________________________ Valve Shim Calculator Used to help determine the shim size needed to correct valve clearance problems. http://crfsonly.com/calculators/crf450-valve-shim-calc.php Displacement, Gearing, Piston Speed & Shim Size Calculator Used to help determine displacement size, piston speed, MPH by gearing and shim size. Calculator is a downloadable EXE file to stored and run from your computer. http://www.xcracing.com/gabe/quad_calc.exe (Thanks 86atc250r) _________________________ GRAPHS & CHARTS _________________________ Racing Fuel Mixing Chart (IMG:http://i42.photobucket.com/albums/e318/gumby46/TRX450R/gasmixchart.jpg) 100 Octane Unleaded Racing Gasoline is the ideal fuel for the high performance enthusiast who requires unleaded fuel. With the use of this custom blending chart, you can economically reach the exact octane number your vehicle requires. First determine the octane number you desire. Then fill your tank with the number of gallons of Unleaded Super 92 octane. Unleaded gasoline enhanced with alcohol should not be used. Next add the number of gallons of 100 Octane Unleaded Racing Gasoline. Blending to the desired octane number will be automatically accomplished. * Jet Conversion Chart (IMG:http://i42.photobucket.com/albums/e318/gumby46/dot%20org/JetChartFull.jpg) (Thanks GPracer2500/cataway/TRX450rlude/El Duner) *
Oct 14 2006, 07:10 PM
Post
#2
Lately I've really come to realize, just how much online reference material is available for the 450R. If you scour the .ORG you'll find it full of links, charts and diagrams that can make life so much easier. I thought I would start a thread to allow us consolidate this information into something that's more readily accessible. Maybe put something together worth getting pinned for future use. I've tried to get us started by compiling the different online references that I've grown to know and love. I want to apologize now for any mistakes their may be and I want to make sure to recognize those that created some of these references. I've tried to make note of it when I know there is someone to thank, but if I have missed something or somebody please let me know. This is all other peoples time and effort given to us to make life a little easier. I'm looking forward to seeing what other jewels of information people know about. If we could just try our best to keep the reply's clean, clear and simply about facts and numbers as opposed to opinion and debate. Lastly, keep in mind that we want this to be easily searchable in the future. So make sure to clearly label and title the information, links, graphs or diagrams that your posting.
If you want to just PM me with the information you have I can post it with all the rest. Also if you notice links no longer work or have mistakes, PM me and I will correct them. -------------------- Mark
![]() 2005 TRX450R - Red HRC Kit (What is left) 12.25:1 Venom Piston Venom Porting HotCams Stage 2 DASA Exhaust System ESR Intake (Ported by Bob McKray) JD Performance +2 STD Travel Race Arms 2007 OEM Swingarm w/ GT Thunder Rear Re-Valve and MX Link RPM Dominator II & Anti-Fade ...More pics and specs... Online Reference Material for the TRX450R |
Dec 9 2007, 10:35 PM
Post
#3
Everything in Moderation. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8855 Joined: 1-February 05 From: North Texas Member No.: 1345 |
I'm closing this topic. However, should anyone need to discuss something in this thread or want to add some info to it, PM me or Gumby with the info and we'll be sure to get it updated. If you have any questions regarding the topics discussed in this thread, start a new topic in the Engine section with your questions.
If you are going to be DUMB you better be TOUGH. TRX450R.ORG cam Guide. TRX450R How-To Guides. Thanks to OKTRX450R. 450R Valve Shim Calculator. Thanks to CRFs Only. RedishConstruction.com |
| Lo-Fi Version | Time is now: 20th November 2009 - 04:47 PM |
