Hi normally I'd check the manual for this but I don't have one for my 2005 trx450r and can't find a download for one. What my quad is doing is when I have the clutch pulled in and in first gear it wants to roll forward. Even if I push the little tab all the way forward that the clutch cable pulls on top of the left side of the case it still rolls forward so there's no way it can be my clutch cable. So I'm guessing it's the clutch plates/springs? So what I'm wondering is how to check if those are bad. I know I'm going to have to take them out but then what? Do I measure the plate thicknesses and compare them to certain specs? Never done a clutch before so any info is appreciated. Thanks
Sounds more like your basket is notched. Way I always tested clutches is get up to a higher gear, the higher the better and let the bike get down in the lower rpm, way down in rpm. Then cram the throttle and if the bike accelerates normal than the clutch pack is fine. If the engine starts revving but not picking up speed then the clutch is slipping, it is a lot easier to notice in a high gear. There are several links to manuals in the engine section, probably under FAQ. It will have the specs for the clutch in it if you want to measure it.
iv heard about clutch baskets getting notched but didn't realize thats what my problem could be. so is it okay to just sand down the notches until its flat again? or will there be to much slop?
Very well could be your clutch basket fingers that are grooved . Most guys will attempt to file it down to smooth them out if it's to not just you will have to just replace it
I'd look at it. If the oil smells burnt, then the fibers are probably fried. If the metals are dark blue then they were overheated, maybe warped. Measure the springs to tell if they are gone. Look at the basket and inner hub to see if it's grooved. Then replace what you need to. Tusk makes a decent, affordable clutch kit for lower HP motors:
Related Threads
Honda TRX 450R
1.2M posts
52.1K members
Since 2004
