Oil change. - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 14 (permalink) Old 12-29-2012, 12:01 AM Thread Starter
Oil change.
Hello. I have a 07 trx450er. Just changed the oil tonight and let it all drain out and took the filter out and put new one din. New oil. And then started it just it off and it's already black. Why? This is what I do in order.
1 take drain plug out.
2 take oil filter out.
3 wait for it to finish drains till it just drips.
4 crank it for 2-3 second intervals to get the excess oil out
5 put filter in
6 drain plug in.
7 fill it in between high and low.
8 start it.
9 check level and fill as nesccerey.
10 check it again.
By this time the oil is pretty much black. I'm I not doing it right? I just don't understand. Not even one ride on the thing. Please help.
Michaelrocksyou26743 is offline
post #2 of 14 (permalink) Old 12-29-2012, 01:07 AM
Duner Dork
04trx450duner's Avatar
Dude, same problem here! Haha, noticed after changing oil (only idling) it would be black already..which oil you running?
2004 "HONDA" TRX450R
K&N/OUTERWEARS/LID OFF
S2HC
CP 12:1 PISTON
YFZ FCR 42.5 BORED CARB W/NOSS
HMF SPORT SERIES FULL EXHAUST
DYNATEK CDI
HID (RIGID 6" LED BAR SOON)
RACECUT FENDERS
SKAT TRAK HAULERS 20X10X8 ON BL DWT WHEELS
MAXXIS RAZRS ON ITP BLACK P.C. WHEELS
ISHOCK LT SETUP
ALBA PROELITE PROPEG NERFS
PROTAPER CONTOUR FATBAR
TMD CHAIN ROLLER/GUIDE
TBC...
04trx450duner is offline
post #3 of 14 (permalink) Old 12-29-2012, 01:09 AM Thread Starter
Maxima? I believe thats the brand. 10w-40.
post #4 of 14 (permalink) Old 12-29-2012, 01:16 AM
Duner Dork
Oh ok, I used to run Lucas synthetic oil 10w-40 and seen that it turned black really quick with idling, now running rotella T 15w-40 and still kinda does the same, trying to figure out why..
S2HC
CP 12:1 PISTON
DYNATEK CDI
RACECUT FENDERS
ISHOCK LT SETUP
TBC...
post #5 of 14 (permalink) Old 12-29-2012, 01:18 AM
Duner Dork
Read this thread lol
Oil very black
S2HC
CP 12:1 PISTON
DYNATEK CDI
RACECUT FENDERS
ISHOCK LT SETUP
TBC...
post #6 of 14 (permalink) Old 12-29-2012, 03:06 AM
prlandry's Avatar
the new oil is just mixing with what's leftover old oil in the engine..... nothing to worry about if you change your oil often.
prlandry is offline
post #7 of 14 (permalink) Old 12-29-2012, 03:16 AM
mypowersports2012's Avatar
It's completely fine!
2006 TRX450R OCP 500
-66hp/38tq-
-OCP +1 head
-Web cam 242/812+5
-Sparks 101
-CP 12.8:1 pump gas
-Stock stroke
-Monster big core shorty
-FCR 43.5
-FCI
mypowersports2012 is offline
post #8 of 14 (permalink) Old 12-29-2012, 09:55 AM
ridinredjav's Avatar
just need to change your oil more often
04 honda TRX 450R
ridinredjav is offline
post #9 of 14 (permalink) Old 01-13-2013, 03:58 PM
oil change
I just got a 07 trx and want to change the oil before i take it for a ride. can some one recomend aoil type to use?
cummins597 is offline
post #10 of 14 (permalink) Old 01-13-2013, 04:09 PM
Duner Dork
Rotella T 15w-40 white bottle
Using iPhone for Tapatalk.
S2HC
CP 12:1 PISTON
DYNATEK CDI
RACECUT FENDERS
ISHOCK LT SETUP
TBC...
post #11 of 14 (permalink) Old 01-13-2013, 09:02 PM
Nytroxxx's Avatar
^^X2^^
04-06-08 TRX450ER
04 Front end
06 Port and Polished Head +1 Kibblewhite valves all 4 corners
Hotcam Stg 2
Crankworks trued balanced and welded OEM crank with HR Crank Arm
12.5-1 CP Piston
Dasa classic exhaust
Velocity Intake with K&N Outwears Airbox lid Pre-Filter and 08 Intake boot
168main, 48pilot, 35leak
06 Plastics, Fuel tank, Steering tube, and Flexx bars
06 ICM with Green Wire Mod
08 Frame, Swingarm, Axle, and Wheels
Rockstar graphics
Nytroxxx is offline
post #12 of 14 (permalink) Old 01-13-2013, 09:21 PM
Banned
Nothing to worry about.
ridinlow is offline
post #13 of 14 (permalink) Old 01-13-2013, 10:34 PM
Tagels's Avatar
I used to agree that its normal for the oil to be black after a short amount of time, until i recently changed my piston and rings and now my oil even after a few hours is still a brownish color. So now im not sure how normal it is for it to be black...
2004 WORCS 450R:
LSR DC-pro a-arms, PEP PB1 shocks
07 swingarm, LSR DC-6 linkage, PEP ZPS shock, LSR axle
Yoshimura exhaust system, CP 12:1 piston, HC2, Modern Race 37/31 head
DWT wheels and XC V2 tires
Youtube: http://www.youtube.com/user/Aturner855?feature=mhee
Tagels is offline
post #14 of 14 (permalink) Old 01-13-2013, 11:09 PM
Super Moderator
York Racing's Avatar
I've never had that problem. I run the Rotella white bottle and my oil is just brown when it gets changed. Just change it really often and see if it starts clearing up. It might just be some of the sludge build up from infrequent oil changes. Try warming it up before you change the oil too.
Paul York
#77 York Racing
Aaron Symonds
#223 York Racing
Jonah Klein
#120 York Racing
~McNett Performance Suspension~
~Thanks to all the family and friends who support me!!!~
I shall pass this way but once; any good that I can do or any kindness I can show to any human being; let me do it now. Let me not defer nor neglect it, for I shall not pass this way again.
York Racing is offline
