05 450 hard starting - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 13 (permalink) Old 12-30-2010, 06:40 PM Thread Starter
Hi, I just picked up my first 4 stroke quad, got a good deal on on this 05, excellent shape. Its only kick start, and is very very hard to start!!!!! I rode it yesturday for a lil bit after a long time to get it to start, today its flooded bad from kicking it for a while with no luck. It is chilly out, 35, would that make it so hard to start or is there a lil trick to 05's??? Thanx in advance
05yooper450r is offline
post #2 of 13 (permalink) Old 12-30-2010, 06:43 PM
Super Moderator
want2bfast's Avatar
Send a message via Yahoo to want2bfast
what cdi box is in it? Pump the throttle twice and watch it run. Make sure you have new fuel in it.. Then check your jetting and post your mods..
want2bfast is offline
post #3 of 13 (permalink) Old 12-30-2010, 06:45 PM Thread Starter
Also can ya get an electric start kit for this model?
post #4 of 13 (permalink) Old 12-30-2010, 06:47 PM
Super Moderator
want2bfast's Avatar
Yes,, But you dont want to do that.. Kickers are the way to go..
post #5 of 13 (permalink) Old 12-30-2010, 06:51 PM Thread Starter
Only mods on it is a lte dual exhaust, and a k&n filter. it is jetted for that system. So just pump the gas gas twice before kicking it, k I will give er a try, thanx
post #6 of 13 (permalink) Old 12-30-2010, 07:00 PM
Super Moderator
want2bfast's Avatar
Do not touch the throttle when kicking it, it can kick back and blow your cases apart.
post #7 of 13 (permalink) Old 12-30-2010, 07:02 PM
Super Moderator
want2bfast's Avatar
Try to kick it real slow til you feel the vavle can resistance.. then reset your kicker and go for it.. If it is still hard to start check you valve clearances..
post #8 of 13 (permalink) Old 12-30-2010, 07:45 PM
NVTRX's Avatar
This may be a dumb question but are you turning the choke on?
NVTRX is offline
post #9 of 13 (permalink) Old 12-30-2010, 07:45 PM
fantus@hotmail.com's Avatar
It's just the cold they hate it. If I leave my bike outside I have to kick it like 50 times b4 it starts, but if it is inside it will start with 1 or 2 kicks.
04 TRX450R
No lid
HRC sorkel, and tee
Stage 2 Hotcam
K&N air filter
Venom exhaust
50 slow jet
R&D Flex jet
185 main jet
HRC needle middle position
Pirelli tires
Moose Handlebars
Powermadd handguards
K&S killswitch
fantus@hotmail.com is offline
post #10 of 13 (permalink) Old 12-30-2010, 07:58 PM
NVTRX's Avatar
My bike will still start 1st kick in 0 degree weather.
NVTRX is offline
post #11 of 13 (permalink) Old 12-31-2010, 05:52 PM Thread Starter
Yep chokes on, I got a new plug today, and fresh gas (92 oct). I bliped the gas a cpl times and kicked it twice and fired rite up!!!! Thanx guys for the help!!
post #12 of 13 (permalink) Old 06-09-2012, 04:21 PM
Send a message via Skype™ to jlantz493
my 07 honda 450er is so hard to start
i would like to know if any of you would know why my 07 honda 450er is so hard to start you can drift start it and it will start right up but you can crank and crank and it will not start till you get it worm what do you all think it is?
jlantz493 is offline
post #13 of 13 (permalink) Old 06-10-2012, 02:07 PM
Drift start?
TaintedFlamez is offline
