engine and transmission oil - Honda TRX Forums: Honda TRX 450R Forum
 2Likes
post #1 of 31 (permalink) Old 12-06-2008, 10:37 PM Thread Starter
Send a message via MSN to Darylrx7
Whats the best transmission\engine oil for the trex 450r???
Darylrx7 is offline
post #2 of 31 (permalink) Old 12-06-2008, 10:49 PM
TrX450's Avatar
SAE 80w85w... its the hp honda transmission oil, the red bottle
Pro Taper Handle bars
Proarmor Nerfbars
Yoshimura RS-3 Comp Series
K&N Air Filte
TrX450 is offline
post #3 of 31 (permalink) Old 12-07-2008, 02:05 AM
lumi's Avatar
^ YUP and get some HP4M (moly) or HP4S(full synthetic) from honda aswell, ther booth pretty good ENGINE ONLY oils.
2006 TRX450ER
2009 BMW M5
lumi is offline
post #4 of 31 (permalink) Old 12-07-2008, 08:37 PM
andycapp's Avatar
^ YUP and get some HP4M (moly) or HP4S(full synthetic) from honda aswell, ther booth pretty good ENGINE ONLY oils.[/b]
Best oil on engine side I have found is schaffer full synthetic race oil (20/50)
12:1
port/polish
KW springs/valves
Stage2 Hot Cam
Full HMF
andycapp is offline
post #5 of 31 (permalink) Old 12-07-2008, 08:41 PM
Jim
[attachment=35611:OIL_and_...for_450R.JPG]
"Integrity is like Virginity, once its Gone, its Gone!"
cleatus is offline
post #6 of 31 (permalink) Old 12-07-2008, 08:52 PM Thread Starter
[attachment=35611:OIL_and_...for_450R.JPG][/b]
hey thanks thats all i needed!!!!! know which oil for engine and for trans
Darylrx7 is offline
post #7 of 31 (permalink) Old 12-07-2008, 08:55 PM
Jim
Silver bottle for engine and Red bottle for trans.
cleatus is offline
post #8 of 31 (permalink) Old 12-07-2008, 08:58 PM
Send a message via AIM to seth5569 Send a message via Yahoo to seth5569
Does anybody use klotz full synthetic? I think it is 50w.
"if you aint first your last"
61/38 ask me how
I'm pretty sure if you just put a flux capacitor on, change the headlight fluid and the muffler bearings all the time your going to have the fastest bike ever.
seth5569 is offline
post #9 of 31 (permalink) Old 12-07-2008, 10:15 PM
badazz05_636's Avatar
ok so i read this article and then went and check my owners manual and it says to run SAE 10w30 in my transmission. Is there a reason your are running that other stuff? i have an 07 450r and just want to make sure i am running the right stuff. thanks.
Ride red420 likes this.
Steve "MOUTH"Coates
badazz05_636 is offline
post #10 of 31 (permalink) Old 12-07-2008, 10:30 PM
Jim
ok so i read this article and then went and check my owners manual and it says to run SAE 10w30 in my transmission. Is there a reason your are running that other stuff? i have an 07 450r and just want to make sure i am running the right stuff. thanks.[/b]
You can use the regular oil in your tranny I do beleive it is supposed to be the 10W40 though, the stuff in the red bottle is what was originally used in the 250R's it works great. You do not want to use the Oil in the Silver bottle in your tranny, it will cause the clutch to slip.
ranger450r likes this.
cleatus is offline
post #11 of 31 (permalink) Old 12-07-2008, 11:17 PM
i use belray thumper 20 50 in both sides. has been working great for me for over 2 seasons now, i used to use the honda oils but wasnt pleased, they cost more and after one 1 race day they would drain super thin, since ive switched to the thumper ive had no problems, i have to use 20 50 in the trans side because if i use anything else i loose neutral and my clutch does not work properly, ive tried the honda gear oil, ELF gear oil and i forget what else, rockymountain has best price on thumper ive found.
Montgomeryville Cycle Center, Moto-Xperts, Jibbergoon Clothing, SixSixOne/Tag/Sunline, AXO, RealBad Motorsports, Cycra, Braking
2005 450r-Race bike-JB prostyle, JB superlink,Fox/Axis shocks, MXP head, MXP cam, Crf ignition
motoracer58 is offline
post #12 of 31 (permalink) Old 12-08-2008, 04:40 PM
jkulysses's Avatar
The red bottle honda tranny fluid is pretty good but I've had best results with this redline tranny fluid. It got rid of my false neutral and popping out of 4th and 5th gear problem. http://www.redlineoil.com/products_gearlub...mp;categoryID=6
08' Honda 450r Kicker
Curtis Sparks Exhaust, DASA Intake, HCII, Green Wire Mod, Pro Taper Evo bars w/odi grips, 8 Paddle Hauler Xtremes 22x11x10, Kenda Dunerunner Fronts 22x8x10
Future Mods
JH Racing Stock Shock Conversion, Graphics Kit/Seat Cover
Xbox Live Gamertag: JkUlysses79
jkulysses is offline
post #13 of 31 (permalink) Old 12-13-2008, 10:02 PM
06-R_ryder's Avatar
i`ve been using royal purple max cycle in the engine side is there anything wrong with that ?
06ER
Preformance Mods
Full HRC kit
HMF Ballance series slip-on
ESR Modded INTAKE
R&D remote fuel screw
DP Clutch kit
DARK SYNERGY CLUTCH SPRINGS
Other Mods
Kickstart conversion
DG HeelGuard Nerfs
DG front bumper
Tusk parking brake block off
Tusk case saver
Pro Armor Teather Kill Switch
Renthal Bars
ODI lock on grips
PIAA H6M
Trailtech vapor
Outerwears airbox cover
21X12X8 8 PADDLE HAULERS
06-R_ryder is offline
post #14 of 31 (permalink) Old 03-11-2010, 10:05 PM
trx450r_pro's Avatar
can you use klotz mx4 10w/30 in both your tranny and motor? i have a 2007 450r
2007 450er
Gt thunder Front Revalves for 175 Lb Rider
Ella stage 5 rear shock
Ella rear linkage
Houser swing arm
Stage 2 Hot cam
Kick start conversion by TSI
CFM Aluminum air box
HRC Jet Kit
Uni Air Filter
Full Rossier Exhaust
Green Wire mod
G force +2 Rear axel
ASR +2 Front a arms with 05 Spindle and Hub conversion.
AC Pro Peg Nerfs.
Maxis Razrs
Hipper rear bead lock wheels
2002 Honda 400 foreman
2005 Honda 650 rincon
trx450r_pro is offline
post #15 of 31 (permalink) Old 03-16-2010, 01:43 PM
JuiceByTheFoot's Avatar
Send a message via Yahoo to JuiceByTheFoot
I run Royal Purple Max Cycle 20-50 in the motor and Royal Purple Full Synthetic Gear Lube in the tranny side. Its good for wet clutches specifically.
Ya know, there is always a huge debate over what oils to run. I think it all boils down to this. Once you get above the garbage econo, run it in your pinto, oils all work well. One or the other won't blow your motor up or lock your tranny up.
I think is you run good oil, any good oil, you'll be just fine. And really, when you change your oil ever other ride or race, it doesn't matter what oil you run. It's not in there long enough to break down.
I've ran Lucas, Red Line, Royal Purple, Mobile 1, Hondaline oils, Maxima......all about the same. My tranny does shift the smoothest with the Royal in it...jmho. The bottom line it JUST MAKE SURE YOU HAVE OIL IN IT!!!
I prefer to run oil thats actually made, mixed, mfgr'd, and bottle in America. I believe America has better quality control oversight and you get a more consistent product. And it helps our economy not the habeebs.......
The Myth, The Legend, The Man-Child..There can be ONLY one, JUICE....
04-05 Service Maunal, click here!!!
Mrs. Juice
Mixxer
Venom Performance
HogNutz Racing
LR Motorsports
Daryl Rath / Rath Racing
330lbs of full figured sex appeal....[/COLOR]
JuiceByTheFoot is offline
