#1 (permalink) |
I CAN FILL MY OIL UP USING THE SIGHT GLASS RIDE FOR A 1/2 HOUR AND ITS TO THE BOTTOM OF THE GLASS .I CHANGED THE OIL AND FILTER AND PUT A QUART IN IT AND THEN ITS LOW AGAIN 1/2 HOUR. PLEASE HELP
2004 trx450r hott cam II fmf full exhaust esr intake maxxis razers |
| Sponsored Links | |
Advertisement |
#2 (permalink) |
I would start off with the easy things like a new washer/o-ring for the drain plug. I would also check to make sure the drain plug isn't cross threaded or anything.
Another, their is a drain hole on the head of the motor, it's round and kind of funnels in towards the hole. I think oil can come out of there if there is too much pressure. I would also check the hose that comes off of the valve cover to see if any oil is in it. Also, when riding, idling or start up does it smoke at all? If it does, then I would say it's either your rings are worn or valves not seating properly. These motors do use a little oil, but that seems excessive. This is all I can think of for it, but try the inspection type things first and see if anything looks like it could be the culprit. Good luck & hopefully someone else with more knowledge than myself can help you out. Good luck. Jason Reason for edit, I spelled hopefully wrong, lol.
07 450ER With a couple trinkets for good measure |
#5 (permalink) | |
#7 (permalink) | |
#8 (permalink) |
Just put her on a jack, even out the jack pop it into gear sit back and check every possible oil leak spot on her, if there is no leaks call over a friend with another 450 leave them in the garage over night and make cute little trx90cc,lol. once u jack it up u should find a leak
CURRENT MODS Stroker Crank 471cc Venom 14:1 piston Venom Blessed Head HotCams Stage III Dasa Exhuast Esr Intake 15/36 gearing Entire Bike Lowered 3 Inch's All Around Fluidyne Radiator Comming VERY Soon +1 Valves All Around Venom 480 Venom Rat 44mm FCR 25 Shot of N02 |
#10 (permalink) | |
#11 (permalink) | |||
Jerid Sutton Ride Red Black 06 450ER with back up kicker;MotoXperts Motor w/ P&P Head and Tranny Mod;Lots of other overpriced suspension crap Black 07 400EX 05 R6 87 TRX70 http://www.myspace.com/imsroll450r ![]() ![]() ![]() Quote:
#12 (permalink) |
ok so you let it ruan and let it sit i no this sounds CRAZY but after you let it sit after running it shake the quad rock stand on it and rock side to side idk but it works
I WANT TO RACE!!!!!! THEY CALL ME.......NICK ac nerfs douglas beadlock rears holeshot HDs rears clarke 3.9 tank hmf full carbon pipe ac body skid pro armor swing arm skid hand guards maier hood fasst flexx 12degree (and more just cant thing of it athe moment)
| Thread Tools | |
