Old 04-07-2007, 11:45 AM   #1 (permalink)
TRX 450R RIDER's Avatar
Default
hey whats up guys so i need to clean a bike to sell so what should i use simple green i heard is good so what i put that on every thing. thanx for the help.
FOR MORE PICS HERE U GO.
http://i169.photobucket.com/albums/u208/ch...DSCF0244_GW.jpg
http://i169.photobucket.com/albums/u208/ch...DSCF0243_GW.jpg
http://i169.photobucket.com/albums/u208/ch...DSCF0242_GW.jpg
06 HONDA 450ER
DASA PIPE
PRO FLOW AIR FILTER
HC STAGE 2
DYNO JET KIT
ISHOCKS
PHANTOM A ARMS
NATIONAL FRONT BUMPER
DG NERF BARS
ITP HOLESHOT GNCC FRONT TIRES
ITP HOLESHOT GNCC REAR TIRES
G-FORCE EXTENDED REAR HUBS
FLY HANDLE BARS
TWIST THROTTLE
SHOCK COVERS
PRO ARMOR RACING GRAB BAR
PRO ARMOR SWING ARM SKID
HEAT WRAP ON THE PIPE
GREEN WIRE MOD
NO MORE WARNING STICKERS
TRX 450R RIDER is offline   Reply With Quote
Old 04-07-2007, 12:25 PM   #2 (permalink)
Default
I use ZEP citrus cleaner. It works really well. Make sure you spray whatever you put on there off really really well.
2006 TRX450ER
--HRC Cam
--HRC Jetting w/ 48 Pilot and main at 168
--Rossier Full Exhaust
--Dasa filter/intake ring w/outerwear
--AC Nerfs
--AC Bumper
--Moose E-brake block off
--JD +2 std A arms
--JD + 2 swing arm
--RPM Dominator 2 +4 Axle
--JH Racing Triple Rate ReValve (Front+Rear)
--JH Racing Rear Linkage
--Quadtech Hood
--One Industries Seat Cover w/ Foam
--Skat trak Extreme 20x10x10, Kenda Dune Runner 21x8
stang233 is offline   Reply With Quote
Old 04-07-2007, 12:36 PM   #3 (permalink)
Default
I use automotive simple green but have also used the ZEP citus cleaner. Both work well. Just spray the entire engine (or quad) and work it in with a small brush. Then rinse off and do it one more time if needed. If you want it to look realy clean (no water spots) use a leaf blower to blow everything dry.
So, you selling the R to get another?
Nor*Cal is offline   Reply With Quote
Old 04-07-2007, 03:16 PM   #4 (permalink)
Banned
Location: Monterey, California. no where near a good place to ride...
Send a message via AIM to quadking450r Send a message via MSN to quadking450r Send a message via Yahoo to quadking450r
Default
gunk foaming engine cleaner works like a charm with a brush, tooth brush. real good for the grime on the frame that doesnt come off w.o scrubbing.
quadking450r is offline   Reply With Quote
Old 04-07-2007, 11:57 PM   #5 (permalink)
Default
thanx i got some simple green and it looks great. thanx guys.
06 HONDA 450ER
DASA PIPE
PRO FLOW AIR FILTER
HC STAGE 2
DYNO JET KIT
ISHOCKS
PHANTOM A ARMS
DG NERF BARS
FLY HANDLE BARS
TWIST THROTTLE
SHOCK COVERS
GREEN WIRE MOD
Old 04-08-2007, 02:54 AM   #6 (permalink)
450R Racer
prlandry's Avatar
Default
What I did a few times now is spray some armorall a few places around the engine like the rad hoses, clutch cable and such. I also put some on my shock. It made it shine like new.
I usualy just wash it with a pressure gun and rarely take time to clean it real good. I hand washed it at the begining of the winter. It stays cleaner much longer.
I like winter trail ridding.
prlandry is offline   Reply With Quote
Old 04-08-2007, 10:54 AM   #7 (permalink)
sredish's Avatar
Default
simple gree works well.
<span style="color:#FF0000">450R Valve Shim Calculator. Thanks to CRFs Only.
RedishConstruction.com
sredish is offline   Reply With Quote
Old 04-09-2007, 01:46 AM   #8 (permalink)
Default
Honda Brite, anyone tried it? I used to work for a Honda dealership as a mechanic and we had access to tons of this stuff, we always used it on engine bays when we did a major service. It was meant for a bike, but worked wonders on engine bays. I had a stock of this, but recently ran out.
warriortch is offline   Reply With Quote
Old 07-29-2008, 08:36 PM   #9 (permalink)
Default
Honda Brite, anyone tried it? I used to work for a Honda dealership as a mechanic and we had access to tons of this stuff, we always used it on engine bays when we did a major service. It was meant for a bike, but worked wonders on engine bays. I had a stock of this, but recently ran out.[/b]
wondering about this as well. Its expensive stuff but I wonder if its worth it.
Golfer2000 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
