2007 With Negative Camber - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 05-16-2017, 05:59 PM Thread Starter
I just purchased a 2007 TRX450er about a week ago as the 3 owner. The bike has noticeable negative camber. I was thinking I could correct this using the tie rod adjustment but quickly learned differently.
Everything in the front suspension seems tight except a little play in the front wheel bearings. I have a set of those ordered. The one difference with this quad is for some unknown reason, the original owner replaced the stock front shocks with a set of 400ex front shocks. A lot of people swap out there 400ex shocks for 450r shocks but Ive never seen the opposite done before. I was wondering, since 400ex shocks are shorter than 450r shocks, could that be causing the negative camber in this case?
Equalizer is offline
post #2 of 3 (permalink) Old 05-16-2017, 11:32 PM
CJM
CJM's Avatar
The shocks are to short to work properly.
-2006 450R. New WHIP..
CJM is offline
post #3 of 3 (permalink) Old 05-17-2017, 04:48 AM Thread Starter
Ok. I was wondering. I was planning to get a set of 450r front shocks for it anyway.
