Shift shaft seal - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 8 (permalink) Old 06-02-2013, 05:39 PM Thread Starter
Shift shaft seal
Went riding today and half way through the ride noticed oil coming from the seal around my shifter. How hard is this to fix and where do I get a new one
qaudtard is offline
post #2 of 8 (permalink) Old 06-02-2013, 07:50 PM
sb/ss pump gas kickin ass
bigcountrydude's Avatar
take the 8mm bolt off the shift lever and pull it off. pick the old seal out with anything you can find. push the new seal in flush with the case. can get oem parts from motosport.com or babbittsonline.com
#224
Chrome valve stem caps.
#RememberTheBuster
bigcountrydude is offline
post #3 of 8 (permalink) Old 06-02-2013, 08:29 PM
Super Moderator
York Racing's Avatar
I have used a wood screw to remove the old seal. Tap it into the seal, then screw it in a little bit until it has a good bite. Then grab the screw head with pliers and pull it out. Then just tap the new one in gently until it is flush. I have always had good luck with bikebandit.com
Paul York
#77 York Racing
Aaron Symonds
#223 York Racing
Jonah Klein
#120 York Racing
~McNett Performance Suspension~
~Thanks to all the family and friends who support me!!!~
I shall pass this way but once; any good that I can do or any kindness I can show to any human being; let me do it now. Let me not defer nor neglect it, for I shall not pass this way again.
York Racing is offline
post #4 of 8 (permalink) Old 06-02-2013, 09:19 PM Thread Starter
It's that easy
qaudtard is offline
post #5 of 8 (permalink) Old 06-02-2013, 09:39 PM Thread Starter
I've looked for oem parts and I've found everything but the shift shaft seal does it go by another name?
qaudtard is offline
post #6 of 8 (permalink) Old 06-03-2013, 12:22 AM
hillshooter450r's Avatar
try part#91203-ka4-771 from rocky mountain. i think its the right #/part. should'nt matter what year,same part.
hillshooter450r is offline
post #7 of 8 (permalink) Old 06-03-2013, 10:26 AM
Super Moderator
32 Oil Seal (14 X22 X5) (Nok) 91203-KA4-771 $3.42
Thats from CheapCycleParts. Under OEM parts, Crankcase section.
Paul York
#77 York Racing
Aaron Symonds
#223 York Racing
Jonah Klein
#120 York Racing
post #8 of 8 (permalink) Old 06-05-2013, 02:39 PM Thread Starter
Thanks guys for the help got my seal today
qaudtard is offline
