Lock nut for rear spring wont budge - Honda TRX Forums: Honda TRX 450R Forum
Old 01-24-2013, 04:04 PM   #1 (permalink)
Ultimate450r's Avatar
Default Lock nut for rear spring wont budge
The locking nut to adjust my rear spring is stuck. I have soaked it in WD-40 and even after that it won't move using a screwdriver and hammer. I am just eating into the notches with the screwdriver. Any suggestions? Thanks for the help even if this is a stupid question.
Ultimate450r is offline   Reply With Quote
Old 01-24-2013, 05:26 PM   #2 (permalink)
Tagels's Avatar
Default
Are you trying to loosen the jam nut on top first?
2004 MX 450R:
Houser +2.25 a-arms,
Fox float X evol front shox, Dura blue X-33 +4" axle,
GTT MX linkage, Fox podium X rear shock, Houser +2" steering stem, Motoworks SR4 G2 full exhaust system, LSR nerf bars, Dunlop quadmax tires
Youtube: http://www.youtube.com/user/Aturner855?feature=mhee
Tagels is online now   Reply With Quote
Old 01-24-2013, 06:01 PM   #3 (permalink)
Default
That's what I meant wont budge. I have the tool and a hammer. Both wont bust it loose. Even with multiple soakings in wd-40.
Old 01-24-2013, 06:26 PM   #4 (permalink)
mailman's Avatar
Default
Use a hammer and a a punch or a long extension. You usually have to hit it pretty hard to break it loose. Just be careful. If the extension slips, it could damage another part of the bike.
Just a little more HP and I should be set.
mailman is offline   Reply With Quote
Old 01-24-2013, 07:25 PM   #5 (permalink)
CJM
CJM's Avatar
Default
Heat
2004 450R. Work in progress
2000 400EX. Too much to list.
CJM is offline   Reply With Quote
Old 01-24-2013, 07:31 PM   #6 (permalink)
Default
That's what I have been using. I also have the tool. It just won't budge
Old 01-24-2013, 08:01 PM   #7 (permalink)
Default
This may sound stupid but I just wanna make sure I'm turning it the right way. From my understanding I would want to turn it counter clock wise since clock wise shortens the spring, correct?
Old 01-24-2013, 10:29 PM   #8 (permalink)
xcracer416's Avatar
Default
counter clockwise is the correst way. toward the exhaust the top jam nut first. if all else fails take the spring off and get evil with it. i wouldnt use a chisel a blunt punch only
2013 OMA number#?........I would like to thank my 2013 season sponsers: DC Cycle and Racing, Jet Suspension, GBC, Teixeira Tech, Pivot Works, Cylinder Works, Hotcams, Hotrods, Vertex Pistons, and Weaver's Auto Parts.
xcracer416 is offline   Reply With Quote
Old 01-25-2013, 06:57 AM   #9 (permalink)
mailman's Avatar
Default
Are you hitting it with enough force? The tabs on the nut usually get a little deformed from the force.
You may have to remove the shock and put it in a vice so you have easier access.
You could also try calling some suspension shops and get their advise.
I would be careful with heat and would not recommend it unless you know what you are doing.
Old 01-25-2013, 08:28 AM   #10 (permalink)
Slim's Avatar
Default
And lift the back of the quad up so all the pressure is off of it, try and break it loose and go from there.
Check out my current bike http://www.youtube.com/watch?v=Zib5mfnBYVo&feature=plcp
To This......Coming soon
Slim is offline   Reply With Quote
Old 01-25-2013, 12:14 PM   #11 (permalink)
Default
Thanks for the help guys. I will work on breaking it loose today. Defiantly not using heat because I don't have the tools nor do I know well enough what I am doing. Even using the little tool I got from i shock when my front suspension came in it didn't want to budge when I hammered on it. From the looks of it, this spring hasn't been adjusted for years. Its an 05 and once the owner got it adjusted it hasn't been touched since is my thoughts. Gave it a nice few soakings in wd-40 the last couple days as well.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
