Bogging in the sand - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 14 (permalink) Old 05-20-2012, 02:58 PM Thread Starter
2L8
Bogging in the sand
Bought this quad used, previous owner bought it new. He was an older guy he kept it very clean and added all the parts in my sig except the tires and rims. My first real ride was to the dunes after i put the paddles and rims on (first time i have ever ridden with paddles). The quad bogs a little when its not being revved up, its the worst while trying to take off in 1st. The engine seems to run perfect otherwise. I'm thinking i should change the sprocket size or it could be the jetting. What size sprockets? Front or rear or both? You guys are the experts, help please!
2L8 is offline
post #2 of 14 (permalink) Old 05-20-2012, 05:37 PM
ttrx450r's Avatar
whats your set up?
what sprockets are on there now? don,t guess go look
any motor work?
whats your weight?
ttrx450r is offline
post #3 of 14 (permalink) Old 05-21-2012, 01:48 AM Thread Starter
2L8
Stock 14-38, i weigh 170 w/gear give or take a few. The only engine mods are hrc cam hrc jets and uni air filter.
2L8 is offline
post #4 of 14 (permalink) Old 05-21-2012, 02:46 AM
MadMike's Avatar
If it bogs when not revved up, then rev it more on take off. It takes alot more to get going in the sand than on any other surface. It could be a jetting issue, but its most likely the case that you just need to give it a little more of that go juice.
2008 450ER
-Pro Armor (Revolution nerfs, MX bumper, Mx grab bar)
-Fasst Flexx bars
-Powermadd guards
-HMF S/O
-Uni air filter
-DDM Tuning 55w HID's (Brighter than the sun, but way cheaper)
-ODI Rogue Lock-on
-Outerwears box lid cover
-ITP Pro Series GP on all 4
-Maxxis Razr Blades front and back
-162 Main (runs better than it does with a 165)
-Stickers (add 15 horsepower)
Don't paint your exhaust with that high temp stuff, just wrap it
MadMike is offline
post #5 of 14 (permalink) Old 05-21-2012, 04:00 AM Thread Starter
2L8
I just really dont like revving the crap out to take off, im kind of
afraid im gonna burn the clutch out, It acts more like a two stroke the way it like top end. It cruises in low rpm in 2nd,3rd,4th fine but when you try to roll on the gas it starts bogging, i have riden many other 4stroke quads and dirtbikes just never with paddles and i have this problem
2L8 is offline
post #6 of 14 (permalink) Old 05-21-2012, 01:01 PM Thread Starter
2L8
the more i think about it, i think a sprocket change will solve my problem. the motor doesn't bog any other time through powerband or other rpms really. i don't really mind losing some top end speed. any ideas on sprocket sizes front/rear?
2L8 is offline
post #7 of 14 (permalink) Old 05-21-2012, 02:04 PM
ttrx450r's Avatar
You sound like its set up correct ..14-38 should br good ...your could try a 12 up front ...just in the sand ..
ttrx450r is offline
post #8 of 14 (permalink) Old 05-21-2012, 02:48 PM Thread Starter
2L8
is dropping two teeth too drastic? preferably i would like to change it once and leave wether i ride on dirt or sand. i would like a little more acceleration vs top end speed anyway. i just dont like having to hammer the gas and drop the clutch to get the tires spinning to start or medium gas and feathering the clutch like crazy in the sand. maybe down 1 in the front or up 2 in the rear, does that sound about right? any pros/cons on front vs rear change? sorry about all the question i just like to make the right decision when buying parts so i'm not disappointed with the result feeling like i wasted money.
2L8 is offline
post #9 of 14 (permalink) Old 05-21-2012, 03:45 PM Thread Starter
2L8
also any recommendations on vendors from this site that could hook me up with front and rear steel sprockets and decent chain for a good price that could be in cali by thursday? probable need a chain breaker too.
2L8 is offline
post #10 of 14 (permalink) Old 05-21-2012, 03:56 PM
450r Dunner
jimmy450r's Avatar
the 04/05 hrc cam is a top end cam, if you want its power you have to get into it's rpm range
wind it up and let it go, the sand adds resistance to everything. Just go try to run up a dune and your body will be bogging lol
drop one tooth in front will help but your cam wants to be rev'd
06 trx450r
2013 crf450r
2009 crf150r
08 trx400ex
08 trx250ex
2011 rzr S LE
jimmy450r is offline
post #11 of 14 (permalink) Old 05-21-2012, 04:08 PM Thread Starter
2L8
i think i'm going to drop a tooth in the front, i noticed honda equipped the 06+ with a 13 tooth instead of the 14 tooth. what size chain will i need for the dropped tooth and stock rear end setup? i appreciate all the help now i just need a deal on a 13 tooth steel front, 38 tooth steel rear, decent chain, chain breaker, and i might as well throw a case saver for good measure that can be here thursday.
2L8 is offline
post #12 of 14 (permalink) Old 05-21-2012, 04:15 PM
hondarider05's Avatar
Just tighten your chain if your only going one size smaller... no big deal
hondarider05 is offline
post #13 of 14 (permalink) Old 05-21-2012, 07:36 PM
ttrx450r's Avatar
I ment 13 ...
ttrx450r is offline
post #14 of 14 (permalink) Old 05-22-2012, 04:11 AM Thread Starter
2L8
thanks for the help, sprocket is on its way
2L8 is offline
