#1 (permalink) |
hey guys I have JD plus 2 a arms. The only adjustments to make the alignment correct is the camber....(the big nut on the a arm) and the toe adjustment(tie rods) Correct? If I am correct I understand that the camber has to be properly adjusted first. So how should I set up the camber? Thanks...I need help
<span style="color:#800080"><span style="font-family:Lucida Console"> |
| Sponsored Links | |
Advertisement |
#4 (permalink) |
There is usually never any instance where you would want 0 degrees of camber.
Someone that knows for sure will probably chime in, but IIRC you want 2-3 degrees for general riding, and 3-4 for motocross. I have mine set at 3 degrees and I ride every type of terrain and it works well for me. I use a magnetic angle finder or usually an electronic level to set camber and it works great.
2005 450R Black everything and lots of parts 2005 450R Less black and less parts |
#5 (permalink) |
I ride MX and some sandy trails......in my garage I have basic tools...how do I set my camber up correctly bf I do the toe adjustment? Thanks guys
#6 (permalink) | |
http://www.jet-motorsports.com/id5.html
07 450er pro design filter jd standard +2 JH stock tripple revalve dual rear w/ linkage tags w/ odi ac nerfs,front bumper and rear grab Houser +2 stem green wire cut RE 42.5 fcr RE Gen 1 port web cam 208 ferrea valves +1 exhaust kibble white springs wossner 12:1 piston Dasa Classic Tuned by Rage Atv 54.62hp/32.77tq My Masonic emblem adds 5 horsepower. |
#7 (permalink) | ||
#10 (permalink) |
You want Negative camber and Positive caster. The tire needs to be "in" at the top so when you throw the bike into the corner the top of the tire goes out and you keep the tire contact patch as vertical as possible.
One Slow Sleeper 408 Puma Cheap aint bad ass and bad ass aint cheap. |
#11 (permalink) | |
#13 (permalink) | ||
#14 (permalink) | ||
But again, for future reference it is negative camber.
| Thread Tools | |
