#1 (permalink) |
hey i want to lower my quad a little but i dont want to buy the a arms to do it. i saw some lowering kit without doing the shocks and a arms do they work thanks.
<div class='codetop'>CODE<div class='codemain' style='height:200px;white-space:pre;overflow:auto'> long_code_here = '; C:\Documents and Settings\Beverly Luttrell\My Documents\My Pictures\Taira and Dillion\trx450\8-2-2009 |
| Sponsored Links | |
Advertisement |
#3 (permalink) | |
#4 (permalink) |
i wouldn't think you would want it lower if you ride desert? don't you need all the ground clearance you can get? and most of the lowering kits do not recommend jumping.
'05 trx450R Black HMF full sport carbon HC2 39mm fcr head porting by me +1 exhaust valves 12:1 CP piston '08 Raptor 250 SE Custom stock |
#5 (permalink) | |
#6 (permalink) |
not sure what you mean by "center balance".
do you mean stability? maybe you should look at wider axles. i run a set of G-force extended hubs on my stock axle and that makes it a full 50" in the rear. they have worked out well for the last 2 years with some big jumps and some pretty hard landings, and i wiegh 240lb.
| Thread Tools | |
