Old 02-12-2009, 10:27 PM   #1 (permalink)
Cloventhal's Avatar
Default
I jus went out to lube my clutch cable with this new tool i got and when I put the lever back on, and pulled the clutch in, the bike wont roll...... its staying in gear. I rode it around yesterday no problem. It has always seemed like it was easier to roll in neutral than it was in gear with the clutch pulled in. I tightened/ adjusted the clutch cable as much as i could and still could not get the clutch to engage..... Think its time for a new clutch basket or something? I have no experience with clutches yet!
<sub>Charlie Loventhal
2005 TRX450r Slightly modified.....
Braaaaaap!</sub>
Who cares about how fast you can go in 5th gear pinned....... i would rather worry about how fast I can get to 5th gear pinned. Oh and Suspension > Engine
Cloventhal is offline   Reply With Quote
Old 02-12-2009, 11:01 PM   #2 (permalink)
Default
is the bike running or off when u try to roll it? With the engine off the bike will not roll with the clutch pulled in! engine needs to be running for the clutch to work properly. sounds like everything is operating properly to me.
2009 Sponsors- Jibbergoon Clothing, Montgomeryville Cycle Center, Moto-Xperts, ASV, Tag, Sunline, Six Six One, HMF, FOX Shox, Team Industries
2005 450r-Race bike-JB prostyle, JB superlink,Fox shocks, team axle/antifade, Flexx, Hiper, MBR/Baldwin motor
2005 450r-Practice-JB/DC6 chassis, Fox shocks, team axle, Flexx, McM motor
motoracer58 is offline   Reply With Quote
Old 02-12-2009, 11:11 PM   #3 (permalink)
Cloventhal's Avatar
Default
I havent tried starting it yet..... I suppose i could go try but i used to be able to roll it in gear w/ clutch pulled in while the engine was off...... i dont see how i could jus lube the cable and lose the ability to do that
Braaaaaap!</sub>
Old 02-13-2009, 12:06 AM   #4 (permalink)
DickBob's Avatar
Default
I havent tried starting it yet..... I suppose i could go try but i used to be able to roll it in gear w/ clutch pulled in while the engine was off...... i dont see how i could jus lube the cable and lose the ability to do that [/b]
Yeah man, mine is the same way I think. Just try it running. You may need to adjust your cable but other than that you're probably good.
-Jason
&#39;07 ER
Cracked thermostat cover
DickBob is offline   Reply With Quote
Old 02-13-2009, 01:33 AM   #5 (permalink)
jebbin12's Avatar
Send a message via AIM to jebbin12
Default
-Jason
You probably just need to adjust your cable since you took it off to lube it. You may not have gotten it put back on the same way.
2007 Honda TRX 450R Race Bike
2004 Honda TRX 450R Play Bike
AMA XiiR Pro Quad National Champion
EDT National Pro Lites and Pro-Am
AMA District 17 Dirt Track #12
Huge Thanks To My Sponsors
Wicked Motors----------------------------Answer Racing
TNT Actionsports--------------------------Redline Oils
Hinson Clutch Components--------------Utopia Optics
Mobile Entertainer------------------------Roberts Racing
Spring Street Automotive----------------Titan Wheel
SaveMore Carpet and Rug Gallery
jebbin12 is offline   Reply With Quote
Old 02-13-2009, 01:53 PM   #6 (permalink)
Cloventhal's Avatar
Default
Ok I went outside and tried to start it in gear with the clutch pulled in and it jus tries to roll forward as i kick it. When i put it in neutral and kick it over itll start right and everything..... so i rode it in the field and when i get on it itll kind of slip like the clutch is still engaged however if i just give it a little gas and coast around its fine although there is some noises i dont think ive heard before. Im gonna go try and adjust it some more.
Braaaaaap!</sub>
Old 02-13-2009, 02:16 PM   #7 (permalink)
Cloventhal's Avatar
Default
Nevermind guys..... I jus needed to adjust the part above the shifter..... ready to ride!
Braaaaaap!</sub>
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
