Old 08-13-2008, 05:02 PM   #1 (permalink)
Default
Can you do this ?
my o7 is a kicker , and the 05's are easier to find , + .. everybody here has E-start 06+.
Ex_Rider43 is offline   Reply With Quote
Old 08-13-2008, 05:49 PM   #2 (permalink)
450R Racer
quadforce*com's Avatar
Default
I was looking to do the same thing but the pipe mouts are different. you will have to work with that if you do I also read that you have to do something different to put the 06+ plastic on them.. I do not think it is anything major but I remember reading that it is not 100% bolt and go.
My ATV Set up page
more info on build
2006 TRX450ER
quadforce*com is offline   Reply With Quote
Old 08-13-2008, 06:25 PM   #3 (permalink)
hondaman01's Avatar
Default
I was looking to do the same thing but the pipe mouts are different. you will have to work with that if you do I also read that you have to do something different to put the 06+ plastic on them.. I do not think it is anything major but I remember reading that it is not 100% bolt and go.[/b]
i have 07 plastic on mine and the rears are a direct bolt on the front/hood area is whats different
i think it would work except you would also need a 04-05 grab bar due to the exhaust mount
Sponsor-
Contact HRE for your engine needs
www.hungracingengines.com
hondaman01 is offline   Reply With Quote
Old 08-13-2008, 08:05 PM   #4 (permalink)
450R Racer
Default
ok cool I must have misunderstood. sounds like you may have a plan then.
My ATV Set up page
more info on build
2006 TRX450ER
Old 08-13-2008, 09:15 PM   #5 (permalink)
Default
Not sure if you can make it work but I have a used 05 sub-frame I would sell you for $50 + shipping if you want to give it a try. It comes with the seat latch and all of the rubber pieces as well. Everything you need.... if interested I'll take some pictures for you.
And the rear fender would be fine. You'll need to shim it up about 1/2 off the 05 sub-frame so you do not end up with a gap between the seat and the rear fender.
Nor*Cal is offline   Reply With Quote
Old 08-14-2008, 05:02 PM   #6 (permalink)
Default
Thanks for the info guys ,
Nor*cal : is it straight ? try to get a quote for shipiping in Canada .. i might be expensive i dont know .. my zip code is G0M 1R0
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
