#1 (permalink) |
450R Racer
i read someone mention they installed the battery under the hood on their 450er.
does anyone have any pictures of this? im wondering what you used for mounting, running the ground/power should be pretty simple. search isint working for me tonight, and i already made one bad thread. i hope this isint number 2
-John. Quadless, looking for next 4-wheeled ****. |
| Sponsored Links | |
Advertisement |
#2 (permalink) | |
I relocated the battery under my hood on my 07. Make sure that you cut the entire mount off of your subframe and then you can drill some holes into the frame at the front. Place your battery bracket where you want it and then drill your holes to match where your holes are on the frame. You need to countersink the screws so they are flush. I don't have any pictures right now, but I can get you some tonight if you really need them.
Austin Bauer 07 Honda 450R - #333 Open B ***Rowdy ATV Racing...Velocity Graphics...Generation X...Custom Blast Services |
#3 (permalink) |
IS THERE ANY ADVANTAGE OF PUTTING THE BATTERY UNDER THE HOOD? WHY DO YOU WANT TO DO THIS?
07 er 50.5/32.8 VENOM ported head cp 13:5:1 piston bored to 480R hcII hmf exhuast/hrc header jetted with lid off green wire mod pro armor nerfs FOX evol X long travel fronts gibson long travel arms rpm +4 axle TCS re-valved dual rate rear shock IMS ROLL intimidator mx bumper Rox speed fx bar risers and dash panel
#4 (permalink) |
Guest
Posts: n/a
Here is the link to someone that put a batt under the hood of a R.
http://www.trx450r.org/forum/index.php?showtopic=52722 |
#5 (permalink) | |
Steve |
#6 (permalink) | ||
Guest
Posts: n/a
#9 (permalink) | |
Hey Rick what is a batter?
Rick 2006 TRX450ER <span style="font-family:Times New Roman">JETTING SPECS. Elevation 3300ft. Airbox lid removed HRC Main jet #162 stock slow jet #42 HRC NGPR jet 3rd. clip from top Pilot 2 turns out HRC Accelerator jet #55 Accelerator timing screw 1 1/8 turn out <span style="font-family:Times New Roman">EXTRAS HC stage 2 Green wire mod RPM +4 axle Laeger LT +2's 05 front end Pro Taper bars AC nerfs Derisi rear revalve GT Thunder MX link Motowoz LT fronts STU 22x8x10 fronts 6 paddle extreme haulers rear HID conversion kit |
#10 (permalink) | |
Steve |
| Thread Tools | |
