Old 10-25-2007, 08:32 PM   #1 (permalink)
Send a message via AIM to seth5569 Send a message via Yahoo to seth5569
Default
I have a stock swingarm going to the fabshop next week to get extended and was wondering how far I can go and still use the stock rear brake lines? Also how far is too far to use the stock shock setup? Minimal jumping mostly drag racing and such. All jumps are under 8 feet high.
Thanks in advance,
Seth
"if you aint first your last"
61/38 ask me how
I'm pretty sure if you just put a flux capacitor on, change the headlight fluid and the muffler bearings all the time your going to have the fastest bike ever.
seth5569 is offline   Reply With Quote
Old 10-25-2007, 08:35 PM   #2 (permalink)
badinblack's Avatar
Default
Thanks in advance,
Seth[/b]
4"s
Ordinary people, simply doing their jobs, and without any particular hostility on their part, can become agents in a terribly destructive process. Moreover, even when the destructive effects of their work become patently clear, and they are asked to carry out actions incompatible with fundamental standards of morality, relatively few people have the resources needed to resists. -Milgram
R.I.P. Jesse aka Jay Dash you were a great friend for sure! and always will be
badinblack is offline   Reply With Quote
Old 10-25-2007, 08:42 PM   #3 (permalink)
Default
how much it cost u to extend the swinger?
TRX533R
jwilson84 is offline   Reply With Quote
Old 10-25-2007, 08:57 PM   #4 (permalink)
Default
how much it cost u to extend the swinger?[/b]
Probably a lil more than $100. We didn't set a price but I told him it had to be close to 100 and he said he would take care of me. It is a local guy I have known for a while know. He is going to use 1/4 inch aluminum plate with a 90 degree bend on each side to make a piece of channel the width of the arm. And a piece of plate to box it in on bottom with some internal bracing for strength.
61/38 ask me how
Old 10-25-2007, 09:07 PM   #5 (permalink)
Default
Thanks in advance,
Seth[/b]
4"s
So if I have an 07 but I am strectching an 05 swinger I can safely go 4 3/4 and still use the stock brake lines. Due to the fact that the 05 swinger is 3/4 of an inch shorter than the 07. Is this correct?
61/38 ask me how
Old 10-25-2007, 09:11 PM   #6 (permalink)
alkyyfz450's Avatar
Default
Thanks in advance,
Seth[/b]
4"s
on our drag bikes we have used the stock brake line on some plus 8's.
mike
alkyyfz450 is offline   Reply With Quote
Old 10-25-2007, 09:15 PM   #7 (permalink)
Default
Sorry double post
61/38 ask me how
Old 10-26-2007, 06:05 PM   #8 (permalink)
sandshots's Avatar
Default
if you eliminate the bend of the line from the mastercylinder to the swinger that will get you another 3-4 inches.
R.I.P TRX450r
sandshots is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
