Old 02-28-2007, 11:02 AM   #1 (permalink)
Default
Hey I see that some extended A arms are +2+1 or +2+0 or +2+2. Does moving the wheel 1" or 2" forward really help with lets says jumping. I mean would it help avoiding a bad endo? What is the best arm to get. Can you use stock suspention on +2+1 arms and what is better long travel or just extend a arms. Thanks guys.
P.s. Sorry to post twice, but didn't get any resposne.
2006 TRX450ER
--HRC Cam
--HRC Jetting w/ 48 Pilot and main at 168
--Rossier Full Exhaust
--Dasa filter/intake ring w/outerwear
--AC Nerfs
--AC Bumper
--Moose E-brake block off
--JD +2 std A arms
--JD + 2 swing arm
--RPM Dominator 2 +4 Axle
--JH Racing Triple Rate ReValve (Front+Rear)
--JH Racing Rear Linkage
--Quadtech Hood
--One Industries Seat Cover w/ Foam
--Skat trak Extreme 20x10x10, Kenda Dune Runner 21x8
stang233 is offline   Reply With Quote
Old 02-28-2007, 03:51 PM   #2 (permalink)
Architects's Avatar
Default
Im really unsure of the benefits of moving the a-arm to a more forward position. I'm curious myself. As for using the stock shocks you can use them but would be better off getting them revalved. Check out Jd performance for a-arms
2005 Jd/Derisi TRX450R SOLD
2007 CRF250R on the way
Architects is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
