Old 01-06-2007, 06:04 PM   #1 (permalink)
Send a message via AIM to New2This
Default
Is there a Secret to getting the Swing-arm Bolt out on these things or what!? Ive tried everything I can think of with NO success!
Thanks, Blake
2005 TRX450R...Black...(MX/Freestyle Bike)
2004 TRX450R...Red...(Drag Bike)
Lonestar Framed 250R...(Drag Bike)
...B C Racing...
New2This is offline   Reply With Quote
Old 01-07-2007, 03:08 PM   #2 (permalink)
Default
Noone...?
...B C Racing...
Old 01-08-2007, 10:31 AM   #3 (permalink)
Default
It is rusted in, you might have to cut it out. First, turn it on its side and squirt some wd40 on it and let it soak in for a day or so.
double d is offline   Reply With Quote
Old 01-13-2007, 11:23 AM   #4 (permalink)
Default
Yes. Probably rusted between the bolt and the sleeves. I have turned the quad on its side so the bolt can be hit with a sledge swinging down. Its an ugly option, but it is the most force you can apply. Otherwise, I have actually had to cut a swingarm apart to remove it. Used plasma cutter. But you have to be carefull not to cut the frame.
Bottom line, use plenty of grease when installing swingarm.
2007 TRX450ER Black/Flames
2006 Suzuki DRZ400SM Black
2000 TRX400EX Red
QuadMatt is offline   Reply With Quote
Old 01-16-2007, 12:50 PM   #5 (permalink)
Default
Bottom line, use plenty of grease when installing swingarm.[/b]
I just took mine off and it was a bear. What I did was take some bp blast let it soak for awhile than get a mini sledge and pound the **** out of it.
durangolimited is offline   Reply With Quote
Old 01-16-2007, 09:46 PM   #6 (permalink)
Send a message via AIM to r3drider420
Default
dude i hope u dont have to cut it out like i did. im never letting my swing arm bolt go ungreased again i learned my lesson the hard way. good luck
05 450r - 14-1 bw,hotcam2,mixxer port polish,hrc lid/needle/185 jet,frame pced granny smith green,houser +2 regtravel,gt thunder all around,g-force axle,u.m full skid,pro taper bars,hmf slip on, power madd handguards,ac nerfs,9x9 green ring hipers with razors , maier racing hood
#25 ama district 5 class-B
r3drider420 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
