Old 02-12-2006, 01:29 PM   #1 (permalink)
Default
I bent my axle, but now I can't figure out how it comes out. So, how does it come out?
Throttle Hog is offline   Reply With Quote
Old 02-12-2006, 03:20 PM   #2 (permalink)
Default
How bad is it bent... i say if its real bad Cut it OFF!!! lol.. not really someone knows more.. but still try and cut it apart and send us pic
2000 400 EX
Pro Armour Skids
Pro Armour MX Bumper
Pro Design case saver
Outerwears Schock Covers
K&N Filter w/ Outerwears Prefilter
Factory 909 Bars
Factory 909 Grips
Pro Circuit T4 S/O
Nothing but Royal Purple !!
The Day i Die is the Day i know my own Limitations..
DieselSmoke is offline   Reply With Quote
Old 02-12-2006, 03:33 PM   #3 (permalink)
kandc1994's Avatar
Default
do you mean if how to remove it buy method. put a big pipe wrench on the biger nut on the right side of axle there are 2. loosen the bigger one on the left by putting the wrench on it and pull wrench towards the floor or from seat to floor. then back the other nut the same way. remove the clip. if the sleeve does not slide over were the clip was file it a little bit. remove hub and loosen chain take that off and slide it out 123 easy!!!
and
BUY A MANUAL!!!!!!!!!
USE A BIG PIPE ON THE WRENCH WHEN YOU TIGHTEN IT OR IT WILL COME LOOSE!!! BLUE LOKTITE ON THREADS!
to tighten floor to ceiling!
04 530R #132 40plus NEATV
BCS/BETTENCOURTS
kandc1994 is offline   Reply With Quote
Old 02-12-2006, 06:44 PM   #4 (permalink)
MrBullDawg's Avatar
Default
I think it is also a reverse thread so be carefull of that.
Black 06 450R my toy
<span style="color:#FF00FF">HC Stage 2
Venom 14:1 stock bore Piston
Venom Porting
Venom Pipe
Open Air box with Outerwears Air Box Filter
Green Wire Mod
Clutch Mod
Stock Idle jet 55 leak jet HRC needle on 4th clip and 165 main
12/38 or 13/41 gearing to haul my bacon up the hill
MrBullDawg is offline   Reply With Quote
Old 02-12-2006, 11:28 PM   #5 (permalink)
trx_bryn's Avatar
Send a message via MSN to trx_bryn
Default
yea that and take your brakes off.
07 450r
Venom-------Exaust
Sparks-------Air filter
Hrc-----------Cam
Ac------------Nerfs and Bumper
Itp-----------Holeshots, Rims
#27 I got a nice Tail Light for a reason
trx_bryn is offline   Reply With Quote
Old 02-12-2006, 11:29 PM   #6 (permalink)
trx_bryn's Avatar
Default
yea that and take your brakes off,disc and hub and caliper.
07 450r
Venom-------Exaust
Hrc-----------Cam
Old 02-13-2006, 10:05 PM   #7 (permalink)
sandshots's Avatar
Default
leave your tires on until you loosen that nut and have someone sit on your bike while you loosen it, it will help. mine was allready loose so it came out easy. the thread is reversed so turn the nut inwards towards the rotor to expose the clip, remove the clip and turn the nut out . remove tires,hubs,caliper,rotor and slide out the other end. if you hear a clunk at this point your sprocket hit your skid plate, loosen the skid to free up the axle.
if its bent too bad cut it off and be carefull not to drop any metal particles inside the carrier when sliding it through. good luck.
R.I.P TRX450r
sandshots is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
