Ticking noise......Driving me crazy!!! - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 16 (permalink) Old 09-17-2004, 03:30 AM Thread Starter
Send a message via AIM to Novanuttz Send a message via Yahoo to Novanuttz
I need some help here guys!
New 450 with about 10 hours runtime.
Installed usual hi-po add-ons and a new cam.
First cam was HC stage 1, checked clearances several times and lash was spot on, but there is a ticking noise coming from the top end right side, sounds exactly like excessive valve clearance, check valves again, Perfect. noise goes away as throttle is increased, quad runs great. order more hi-po parts including HC stage 2 , remove stage 1 cam and inspect, everything looks great. install stage 2 cam check clearances several times add proper shims, proper break-in at 2500 rpm, everything sounds great, reduce engine to idle and ticking noise once again on right side top end. hmmmmm . Do I possibly have a problem with the decompressor at low rpm? Can I start it without the Decompressor to test my theory. I'm no youngster and have been building drag race motors for nearly 20 years, im not going to let somthing this simple kick my butt. By the way, is the decompressor lash (.006")measured at the roller or the rocker arm?
Thanks
Hot Cams stage 2, J&E 13:1, CHM full exhaust, 13/38 , Renthal bars, K&N, Holeshot H-D tires, ITP Sands Stars w/ T9 wheels(dunes)
Novanuttz is offline
post #2 of 16 (permalink) Old 09-17-2004, 07:29 AM
trx480ryan's Avatar
Send a message via AIM to trx480ryan Send a message via MSN to trx480ryan
I Have the same noise... and cam, if u figure it out, let me know wat it is !!!
1995 Ford Ranger Splash
6'' Rough Country Lift
33'' BFG M/T's On Procomp 1089 Wheels
Super Runner Steering Kit
2004 TRX480R
Bored 30 over, 12.5.1 Comp
Rage Ported Head
Sredrum Bored 42.5 FCR
Powder Coating
Rossier Exhaust
Stage 2 Hot Cam
trx480ryan is offline
post #3 of 16 (permalink) Old 09-17-2004, 10:32 AM
Send a message via MSN to Mitco39
Make sure you guys are sure its commin from where your think...because i had what sounded like the same problem....and it was my crank bearing that eventualy when and took the crank with it. It sounds the same cuz when i would rev it up the sound of the eninge would exeed the sound of the bearing so i wouldnt hear it and i thot it wasnt that big of a deal. well i was wrong. just because about weird noised and they might not be comming from where u think your hearing them. i learned my lesson.
[b]<span style="font-family:Comic Sans MS"><span style="color:#FF0000">Westlock 07'
Mitco39 is offline
post #4 of 16 (permalink) Old 09-17-2004, 03:11 PM
Send a message via AIM to WhiteZee
novanutts, how did you like the HC stage 1? why did you end up switching over to the stage 2?
WhiteZee is offline
post #5 of 16 (permalink) Old 09-17-2004, 03:35 PM
Send a message via AIM to Ride_Red626
If your measuring the valves at the wrong spot they could be out of spec's which would cause a small ticking noise.
Or it could just be the motor... These motors are pretty noisy/klanky to begin with. Even stock mine was pretty noisy, and so was my CRF.
Dave
Ride_Red626 is offline
post #6 of 16 (permalink) Old 09-17-2004, 08:01 PM
Send a message via MSN to trx450Rrider
its ur tranny. notice how everyones does it!!!!!
Methuen MA
06 450R
NE-ATV
#19
OPEN B | 4 STROKE B
BLINGSTAR
KANDK ATV
NORTH READING HONDA
BCS PERFORMANCE
SPASTIC DESIGNS
VCA
MOTOWOZ
trx450Rrider is offline
post #7 of 16 (permalink) Old 09-17-2004, 08:26 PM
Novanuttz, I'm no expert! But, the hotcam is know to make excessive noise! Every hotcam that I have ever heard makes the noise your talking about including mine!! Hotcam noise sounding like the valves are ticking is normal. Just my 2 cents worth!!
JD Performance[/url]
Rico450R is offline
post #8 of 16 (permalink) Old 09-17-2004, 09:52 PM
mine makes noise too. it did when it was stock and has continued after each mod that i have added. i think the motor just is noisey due the light weight materials used for manufacturing a light weight motor. if the materials were heavier/thicker, you probably wouldn't hear a thing. i'm guessing since i have read many similar posts here and elsewhere, that it is nothing more than normal engine noise. and... i HOPE it is too. ^_^
HRC kit - 41mm FCR - JE 13.5:1 piston - DR FatBoy4 exhaust
UM Skids - TAG X5 Bars - IMS Fuel Tank - RPM Hub/Locknut - G Force Axle (+4)
DG Race Peg Nerfs - AC Staduim Bumper - GT Thunder revalve X3 - JD Performance +2 A-Arms
JD Performance +1.25 Swinger - Works Connection Clutch Perch w/hotstart
RedDogg is offline
post #9 of 16 (permalink) Old 09-18-2004, 12:31 AM
Send a message via MSN to clutch
I have the HRC cam and I have picked up some noise also.
I agree with some of you that it is probably the decompressor. I don't believe that the shims would wear enough in the short time to allow enough clearance to cause valve noise.
You could remove the decomp. and put the motor back together to check but...???
Good luck trying to start the thing without the decomp. I weigh 195 and don't think that I have enough a$$ to do it, not to mention the wear on other parts such as kick starter etc.
If you guys think it is too loud come ride my 1986 XR 80. HOLY $HIT!!! I haven't rode it at all this summer since I got my R and now that I have my daughter old enought to get rides I can't believe the motor noise. Not to mention the notchy tranny. I just about ripped into the motor the other day!
West Fargo ND
2004 TRX 450R
PRM swingarm and chassis skid,AC Racing front bumper
HRC Kit, EHS Racing airbox lid, Scotts oil filter
Trail Tech bars and clamp kit, GT Thunder linkage and shock revalve, Holeshot GNC's on ITP GP rims, DASA Full Exhaust
IMS pegs...sweet pieces! IMS Heelguards
Pro Armor Nerfs...LOVE EM...Thanks Luke!!!!
Sparks Racing Air Intake/Filter
JD Performance +2" standard travel A-arms
14:1 Venom Piston
Venom Porting, Venom Pipe
KW valves and springs
2002 Arctic Cat ZR 600
Holtzman ATACC
2 Degree ignition key
Heel Clicker clutch weights
144 studs with 8 inch carbides
1986 XR 80R
BBR skid/frame gusset
Head porting, Carb ported, Air box drilled
Yard racer!!!
Save a Seal, Club a Liberal!!
"Tolerance is the virtue of a man without convictions." -- G.K. Chesterton
"The urge to save humanity is almost always a false front for the urge to rule.” H.L. Mencken
“The object of life is not to be on the side of the majority but to escape finding oneself in the ranks of the insane.” – Marcus Aurelius
clutch is offline
post #10 of 16 (permalink) Old 09-18-2004, 12:50 AM
mine makes it to, sounds like it comes from the trans. ive been waiting to put my cam in, fearing something was wrong with engine. since you guys say that its normal i installed it tonight. boy bye bye bottom end hello top end.(noise still there)
Port Work [/url]
BOONE450R is offline
post #11 of 16 (permalink) Old 09-18-2004, 09:55 PM
its the tranny but the motor isnt that loud. i rode a yfz and it makes crazy sounds. the 450r does too and its just because they both have thin side cases so its lighter and you can hear threw them better
Methuen MA
06 450R
NE-ATV
#19
OPEN B | 4 STROKE B
BLINGSTAR
KANDK ATV
NORTH READING HONDA
BCS PERFORMANCE
SPASTIC DESIGNS
VCA
MOTOWOZ
post #12 of 16 (permalink) Old 09-18-2004, 11:27 PM
I've learned to just ingore engine noises. I know that may be bad, but it will drive you crazy always *thinking* you hear something that wasn't there before. Besides, compare to cannondales these things are quiet, those things sound like they have loose metal knocking around in them...
remlapr is offline
post #13 of 16 (permalink) Old 09-19-2004, 12:49 AM
George Porter's Avatar
The valve clearances are so large that the valves are going to make some noise. If you had a rod bearing on its way out it would keep getting louder.
George Porter is offline
post #14 of 16 (permalink) Old 11-11-2004, 10:01 PM
That is the same spot mine started ticking from. I just got word that my 450 needs a new camshaft and rocker arm.
HAVOK is offline
post #15 of 16 (permalink) Old 11-11-2004, 10:33 PM
86atc250r's Avatar
These motors are pretty noisy/klanky to begin with.[/b]
Hmm.... Mine's pretty well silent (HRC cam and other goodies). No valve noise what so ever.
Makes my 400EX sound like a rattling POS...
Don't have any advice other than make sure you are setting the clearance correctly on the valves >>and<< decompressor assembly
86atc250r is offline
