stroker - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 17 (permalink) Old 06-09-2004, 10:55 PM Thread Starter
Send a message via AIM to PICKLES
what does a stroker kit actually do. I hear about stroker kits for the yfz, the z/kfz/dvx and the 400ex mostly but is there one for the 450r and what in the world does it do and improove etc?
keep it clean and use good grammer for @#$^'s sake!!!!
yea I think that does the trick!^^^^
DO YOU HAVE A PERMIT FOR ASKING STUPID QUESTIONS LIKE THAT!!!!!!
PICKLES is offline
post #2 of 17 (permalink) Old 06-10-2004, 01:28 AM
a "stroker kit" is a crank with more stroke than stock. it increases cc's and is a good way to add torque.
freeride is offline
post #3 of 17 (permalink) Old 06-10-2004, 11:53 AM
First they shorten the rod and then they move the pin on the crank higher up. This makes the piston go higher into the cylinder and lower down creating more room for gas to go into the cylinder. Also, they shave the skirt cause a normal piston would hit with these modifications. Now you can put a smaller spocket on the back and you will not lose anything on the low end. The stroker cause allot of power and allows the motor to rev up higher and still keep its low end all the way though.
JD Performance[/url]
Rico450R is offline
post #4 of 17 (permalink) Old 06-10-2004, 02:50 PM
Send a message via AIM to WhiteZee
if you put a smaller sprocket on the rear, you will be gearing it up, meaning your losing bottom end.
WhiteZee is offline
post #5 of 17 (permalink) Old 06-10-2004, 03:13 PM Thread Starter
Originally posted by WhiteZee+Jun 10 2004, 01:50 PM-->
<!--QuoteBegin-Rico'450R
if you put a smaller sprocket on the rear, you will be gearing it up, meaning your losing bottom end. [/b]
I think that he ment u wouldn't loose any pwr compairing to stock.
PICKLES is offline
post #6 of 17 (permalink) Old 06-10-2004, 07:02 PM
That was the point I was trying to make. A stroker changes your power curve. Making your sprocket smaller, you will not lose any low end. That's why people stroke the motor. I've heard of lowering the sprocket by 2 sizes and you still will not lose any bottom end, plus you will gain top speed! My 465ex stroker had a top speed of 85 with 15/36 gears! B)
And nothing could touch it in a drag race. Until my pump up 450R came along! :ph34r:
Rico450R is offline
post #7 of 17 (permalink) Old 02-01-2013, 12:02 PM
so you would need an new piston for a stroker.
2004 trx450r
hrc kit
lrd pro 4 slip on
cst ambush tires
renthal bars
powermadd handguards
pro armour cross country nerfs
ac racing bumper
maier vented hood
josh oliver is offline
post #8 of 17 (permalink) Old 02-01-2013, 12:07 PM
I wish I was QUIK. . . .
hoser's Avatar
No you do not. And contrary to what was stated above in this 9 year old thread, your piston does not need to be modified. You will only need a new piston if you are changing the bore size. But if you are still running on the stock piston I highly suggest you get a new one.
2005 450R
Black everything, Faster
2005 450R
Black everything, Slower
2004 450R
Under the knife. . . . . .
hoser is offline
post #9 of 17 (permalink) Old 02-01-2013, 12:47 PM
ridinredjav's Avatar
you dont need a new piston with the cheap hotrods stroker crank because it has a shortened rod.
the good way to stroke these motors is to send the stock crank to crankworks and have them stroke it keeping the stock length rod. just have to get a stroker piston or a cylinder spacer
04 honda TRX 450R
ridinredjav is offline
post #10 of 17 (permalink) Old 02-04-2013, 12:01 PM
would a hotrods crank work fine though. and when i get my stroker crank im getting a new cp 12:5:1 with it aswell. but how expensive is crankworks.
2004 trx450r
hrc kit
lrd pro 4 slip on
cst ambush tires
renthal bars
ac racing bumper
maier vented hood
post #11 of 17 (permalink) Old 02-04-2013, 06:41 PM
jrdolejsi's Avatar
Yes it will work. Everyone has their own opinion on the subject. Some say they are great some say they are terrible. I know a few people that have been running them for a few years with no issues.
Also fyi, if you run a 12.5:1 piston you will need to run race gas.
jrdolejsi is offline
post #12 of 17 (permalink) Old 02-04-2013, 07:54 PM
Hm. This is originally from 2004. The Ltr didn't come out until 06.
SHIFTx450 is offline
post #13 of 17 (permalink) Old 02-04-2013, 07:56 PM
Ha. You can tell I had a long day.
Wrong forum!
My apologies.
post #14 of 17 (permalink) Old 02-05-2013, 11:49 AM
[QUOTE=Also fyi, if you run a 12.5:1 piston you will need to run race gas.[/QUOTE]
Really. I thaught 12:5:1 was the highest you could go without race gas. if that is the case then 12:0:1 piston
2004 trx450r
hrc kit
lrd pro 4 slip on
cst ambush tires
renthal bars
ac racing bumper
maier vented hood
post #15 of 17 (permalink) Old 02-05-2013, 11:59 AM
hoser's Avatar
The stroker crank adds .4 to .5 points of compression.
2005 450R
2005 450R
2004 450R
hoser is offline
