Preferred Machinists? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 2 (permalink) Old 05-18-2017, 07:42 AM Thread Starter
I am helping a friend of mine rebuild his '04 with a Hot Rod's crank, Wiseco piston, HRC cam, basic stuff. The original owner gave us two heads, one was complete with valves but someone had (poorly) drilled and retapped the cam tower bolt threads with something slightly larger, and cut the bolts to fit. So I don't want to use that head. The other one was good, but didn't have either intake valve in place. So, I removed the intake valves and lapped them into the new head. One sealed perfectly, the other didn't. The more I thought about it, the more I really would like to do a complete valve job, clean the head up, resurface it, etc.
Don't trust the local shops that were recommended, and judging by how small the head is it can't be that much to ship it somewhere, so sending it wherever isn't an issue. This is one of those things that should be done as best as possible, correctly, the first time. Just want some suggestions on a reputable shop to help us out. Thank you!
- Phil
'05 TRX450R - '05 CBR600RR
phillybuilt is offline
post #2 of 2 (permalink) Old 05-18-2017, 11:11 AM
That One Mod
ghott's Avatar
Send a message via AIM to ghott Send a message via MSN to ghott
Racers Edge AZ is my recommendation. They are some of the best in the business and their customer service and communication is top notch. Give them a call, their phone number is here: Racers Edge AZ - Contact Us
Gary
My 04/05 Honda TRX450R Site
(^^^TRX450R tech articles, dyno testing, pics, vids, and more)
| '04 Racers Edge, AZ - WV #304 Bike...649cc Business Flat Dragger|
| '05 Racers Edge, AZ - Little Bike...450cc Play Flat Dragger|
ghott is offline
