Dasa vs. Rath intake ring - Honda TRX Forums: Honda TRX 450R Forum
 1Likes
  • 1 Post By awheelock67
post #1 of 6 (permalink) Old 05-15-2017, 02:00 PM Thread Starter
Question: The +06 Dasa intake looks to be nothing more then a ring that is inserted into a stock 06+ intake that uses a filter similar in size to the stock one? I recently just purchased a +06 Rath intake ring that inserts into the stock intake for the purpose of preventing the air filter clamp from deforming the stock intake causing leaks. The Rath ring is tapered just like the +05 adapter rings too. Would I be correct in saying the Rath ring is similar to the Dasa intake in that it helps the intake flow better? The Dasa ring is advertised to improve flow where as the Rath ring is advertised to prevent the clamp from being over tightened. Could Rath ring be considered an intake too? Here is a picture of my Rath ring inserted into the intake. Please forgive my messy airbox as it is much cleaner now.
camoweasel is offline
post #2 of 6 (permalink) Old 05-18-2017, 11:32 AM
El Mamito USMC's Avatar
Send a message via MSN to El Mamito USMC
it might help but if you want a real intake get a ROLB intake or FCI. they are worth the money
Zorros Racing Team- Score International #123A
next adventure : Score Baja 1000, 50th anniversary
BAJA 500 finisher
Monsters Exhaust http://monsterquad.com/
www.Immortalatv.com
http://www.shockworxmotorsports.com/ Suspension Specialist
http://www.fasstco.com/product-category/atv FLEXX BARS
https://www.facebook.com/glann.innovations Case savers, Chain Guides,
http://www.pnpsupplements.com/ Supplements for endurance racing
El Mamito USMC is offline
post #3 of 6 (permalink) Old 05-18-2017, 08:58 PM
tim450r's Avatar
Are the dasa rings worth anything, I ended up not needing mine with a newer style uni
tim450r is offline
post #4 of 6 (permalink) Old 05-18-2017, 10:11 PM
awheelock67's Avatar
Well Dasa is a little bit almost nothing bigger and the rath looks the same size, so the rath doesn't allow to flow more air.
Robl looks awesome
El Mamito USMC likes this.
awheelock67 is offline
post #5 of 6 (permalink) Old 05-19-2017, 08:41 AM Thread Starter
Robl looks awesome
Bigger by how? Bigger filter, bigger intake diameter? It looks like the Dasa ring slides in the stock intake flange just like the Rath one does?
post #6 of 6 (permalink) Old 05-19-2017, 08:50 AM Thread Starter
Here are pictures of the two. Rath racing on left and Dasa on the right. The Rath looks likes it a bit more tapered where the Dasa is flat.
