2005 trx 450r mods - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 10 (permalink) Old 03-28-2013, 03:46 PM Thread Starter
ride4fun's Avatar
Send a message via Yahoo to ride4fun
2005 trx 450r mods
for christmas i bought my son a 2008 kfx 450r, it came with a curtis sparks full system and the Power Commander. we also think that he replaced the clutch. he will hit about 40 mph at the bottom of 3rd. i was wondering what i could do to keep up with him. he blows me out of the water.
ride4fun is offline
post #2 of 10 (permalink) Old 03-28-2013, 03:55 PM
just450trx's Avatar
is yours all stock
06 er
480 cw big bore
port and polish
hc stage 3
lrd pro 4 w/ hrc header
green wire mod
k&n with outerwear
just450trx is offline
post #3 of 10 (permalink) Old 03-28-2013, 03:59 PM Thread Starter
ride4fun's Avatar
pretty much yes i have the hrc end cap and a new sprocket, and have cut open the air box lid. nothing really done to it
ride4fun is offline
post #4 of 10 (permalink) Old 03-28-2013, 04:17 PM
Stage 2 hotcam full exhaust if your money allows it dasa,sparks,rossier,motoworks even. I know when I first got my bike I went with the stage2 hotcam it really woke it up. And what size sprocket did you change to?
05 TRX450R
41mm FCR Carb
Boyesen QuickShot 2 Accelerator Pump Cover/Keihin FCR NCVQ Needle
R&D Flex Jet Fuel Mixture Screw/K&N Filter
Outerwears/Stage 2 Hot Cam
12:5.1 JE Pro Series Piston/Sparks Ported Head
Updated OEM Crank/LSR Exhaust
Precision Clamps/Precision Pro Stabilizer/Tag Handlerbars
+1 Houser Stem/06+ Swing Arm
GT Thunder XC Linkage/IMS Shifter
14/36 Gearing/Moose Poly Case Saver
T.M. Design Chain Slide
ziboogy is offline
post #5 of 10 (permalink) Old 03-28-2013, 05:45 PM
jrdolejsi's Avatar
X2 on the HC Stage II cam and full exhaust. If you can get your head ported too that really helps. Very noticeable gain.
jrdolejsi is offline
post #6 of 10 (permalink) Old 03-28-2013, 07:04 PM Thread Starter
ride4fun's Avatar
i changed it to a 13 i think its been a while its an 05. what about jets? CDI?
ride4fun is offline
post #7 of 10 (permalink) Old 03-28-2013, 07:20 PM
Well I stay in NC so I ran 185 main and 45 pilot jet. As far as the Cdi don't worry about changing it. Put that money toward getting a FCR Carb or getting your head ported
05 TRX450R
41mm FCR Carb
ziboogy is offline
post #8 of 10 (permalink) Old 03-28-2013, 07:55 PM
hawk-trx's Avatar
The cam is your next thing and hrc or sparks needle I would go with a 182 main and 50 pilot.
Then a full exhaust, many good ones to choose from and some good deals in the for sale section. Esr is probably my favorite dasa has been known to make the max power but its not by much. Sparks, yoshi, hmf, and others are all good.
After that, the head is your next step. A decent rec port should add 3-5 hp a real good job 6-10 ( hp cost money)
While you have the head off bump the compression to 12-1 a good forged piston will be a lot lighter and the 1.5 compression helps as well and still run pump gas.
The bad thing about the 04/05 is that it takes more to run with the other quads then the 06 trx but that is where the bad stops. IMO you have a better quad just give it a little help.
CDI is a waste of money, most will loose power compared to the stock unit.
hawk-trx is offline
post #9 of 10 (permalink) Old 03-29-2013, 07:18 PM
jasmoore3's Avatar
Hey neighbor, Don't waste money on cdi (yet) If you're on a budget, buy a decent used full exhaust and a HCII. The stock header is very restrictive. If you haven't replaced the piston yet, I'm sure it's time. The stock piston is a low comp. slug. Yes, you will need to re-jet. Very easy on an '04/'05 carb.
05 trx 513r (batteries are for old ladies)
stock swingarm...yeehaw!
Qrappy rider (me)
Polaris RZR
jasmoore3 is offline
post #10 of 10 (permalink) Old 03-29-2013, 07:50 PM
450 **** Raiser
primos97hunter's Avatar
I done both my head porting and hc2 at the same time. Whole different bike
Alex
07 Trx450R
Engine:
Stainless Ferrea Valves (On stock shimmed springs)
Stage 2 Hotcam
Curtis Sparks Exhaust
55 Leak
Uni Filter
Chassis:
Front Deseri/Jet Stock Revalves
ProArmor Grab Bar and Bullhorn Bumper
ProArmor Nerfs with Stock Heels
Prm Belly and Swingarm Skid
1/4in Steel Sprocket Guard
Custom +1.5in Stock Stem
Flexx Bars
7.5in LED Light Bar
primos97hunter is offline
