What would've caused this??? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 9 (permalink) Old 02-15-2013, 07:35 PM Thread Starter
What do need to check out...see below pic
Engine is/was a 480cc 11.5:1 w/ +3mm crank and a hc3 cam
Now the weird...it's only this bad on the exhaust side of cylinder and and the piston shows no wear to the eye. Glad I was bored waiting for parts and decided to tear into it.
Back on a Honda !!!
Thanks to my sponsors:
Gt Thunder
Thede photography
AXO
Gopro
Dwt
Outlaw racing
Hotcams
Hotrods
Pivot works
Cylinder works
Vertex pistons
racer69 is offline
post #2 of 9 (permalink) Old 02-15-2013, 07:37 PM Thread Starter
To me the only thing i seem so far is that the compression ring gap is HUGE!!
Back on a Honda !!!
Gt Thunder
Thede photography
AXO
Gopro
Dwt
Outlaw racing
Hotcams
Hotrods
Pivot works
Cylinder works
Vertex pistons
racer69 is offline
post #3 of 9 (permalink) Old 02-15-2013, 07:41 PM
Fairly fast foreigner!
OTMTRX's Avatar
Is that grooves in the cylinder? Hard to tell from pic.. piston rock from incorrect piston to cylinder wall clearance would be my guess... and it is a guess... Did it knock when running?
The ring gap would say that might be the case too though..
'06 TRX450ER, '03 XR400r, '04 CRF450r, '05 CRF250r, '06 CBR1000RR (StreetFighter), 07 GSX-R750, '71 CB500, '75 CL360 (Honda Scrambler), '81 Virago XV750 (the 110 Bike).
06 Black TRX450ER (Conv to kicker) "Medium" Big bore! Quikshrk (OCP), Demon, REAZ bits.
OTMTRX is offline
post #4 of 9 (permalink) Old 02-15-2013, 07:45 PM Thread Starter
Didn't knock actually ran pretty good...it was a holeshot monster.hard to keep front end down @ 3/4 to wot
Back on a Honda !!!
Gt Thunder
Thede photography
AXO
Gopro
Dwt
Outlaw racing
Hotcams
Hotrods
Pivot works
Cylinder works
Vertex pistons
racer69 is offline
post #5 of 9 (permalink) Old 02-17-2013, 12:22 PM
leearchibald's Avatar
What does the other ring gap look like? If it was piston rock the skirts of the piston should be beat in pretty good.
04 trx450r
ss/sb
13:1
HC 1
FMF factory4.1
kibblewhite valves
Deshrouded head
leearchibald is offline
post #6 of 9 (permalink) Old 02-17-2013, 01:35 PM
Dirt through filter (probably K&N )!!
dyno is offline
post #7 of 9 (permalink) Old 02-17-2013, 08:07 PM
mx333's Avatar
That is caused by lack of air filter mantiance. Dirt went through the motor. If the cylinder is that bad so is the piston. Probley check the valves as well. The dirt hits the valves before it hits the cylinder.
05 Trx450r(s)
Walsh/Pep/Rath
mx333 is offline
post #8 of 9 (permalink) Old 02-17-2013, 08:56 PM
Only thing that causes that is dirt. sometimes poor plating on the cylinder. On LTR450 stock cylinders you see this alot. And by the color of that oil on your head in the background ( looks dirty) I would say it was eating some dirt. when you put it back together make sure you clean your intake boot real good. It aslo would hurt to tear the bottom end down just to clean & inspect everything
Quadified ATV is offline
post #9 of 9 (permalink) Old 02-18-2013, 01:36 PM
mattonln's Avatar
480cc correct? Stock replated cylinder or cylinder works? Either way, subpar plating.
Dynomite Performance ATV - Glendale, AZ
mattonln is offline
