| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
450 **** Raiser
Id clean the carb. May not be letting enough fuel to the engine therefore making it run hot.
06 Trx450r Electric Start
AC Front and Rear Bumper AC Nerf Bars PRM 1/4in Swingarm Skid Chassis Skid HRP Poly Case Saver Protaper Bars ODI Locking Grips Aluminum W/A Bark Busters YorkRacing YR-1 Ported Head Stage 2 Hotcam Curtis Sparks Full Exhaust R&D Quick Shot Power Bowl Uni Air Filter BikeMaster TruGel Battery ![]() |
#5 (permalink) |
Todays 4 strokes run hot and glowing exhaust is normal, the back fire and idle is most def the Pilot jet and/or air fuel screw in carb or leaking exhaust gasket for backfire.
04-06-08 TRX450ER 04 Front end 06 Port and Polished Head +1 Kibblewhite valves all 4 corners Hotcam Stg 2 Crankworks trued balanced and welded OEM crank with HR Crank Arm 12.5-1 CP Piston Dasa classic exhaust Velocity Intake with K&N Outwears Airbox lid Pre-Filter and 08 Intake boot 168main, 48pilot, 35leak 06 Plastics, Fuel tank, Steering tube, and Flexx bars 06 ICM with Green Wire Mod 08 Frame, Swingarm, Axle, and Wheels Rockstar graphics |
#6 (permalink) |
450 **** Raiser
Yeah, I forgot to ad that it could possibly be the fuel screw maybe falling out. But just check the carb over good
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
