Which clutch kit? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 13 (permalink) Old 05-31-2012, 02:40 PM Thread Starter
Which clutch kit?
I am due for new clutch plates, fibers, and springs....i know a lot of people run crf450r clutches....
What does everyone run minus hinson and rekluse...
I usually grab tusk...have had good luck with them....the crf clutches have a lot more options out there as far as brands go....
whats everone's $.02?
04 450r
FCR Carb
Walsh rear end
PEP shocks all around
Houser +2 +1 a-arms
JE 13:1 piston
Dasa ported head
Web cam
Curtis Sparks exhaust
Lonestar axle
PWR radiator
AC ProPeg Nerf's
matholland is offline
post #2 of 13 (permalink) Old 05-31-2012, 02:55 PM
That One Mod
ghott's Avatar
Send a message via AIM to ghott Send a message via MSN to ghott
The past couple of clutches I have put in mine have been OEM 06/07 Honda CRF450R clutches. They are pricey tho (part number: 06001-MEN-001).
Here's a little write up that may be helpful: GHOTT's 2005 Honda TRX450R Clutch and Clutch Spring Info
Truth be told, the next time I have to buy a new clutch, I'll probably just go with a Rocky Mountain ATV Tusk brand 2006 CRF450R clutch to save some $$$.
Gary
My 04/05 Honda TRX450R Site
(^^^TRX450R tech articles, dyno testing, pics, vids, and more)
| '04 Racers Edge, AZ - WV #304 Bike...649cc Business Flat Dragger|
| '05 Racers Edge, AZ - Little Bike...450cc Play Flat Dragger|
ghott is offline
post #3 of 13 (permalink) Old 05-31-2012, 02:59 PM
#ORsquad
OhaRe's Avatar
Send a message via Yahoo to OhaRe
I have a brand new tusk cluth kit for sale lol I hear a lot people use tusk or just oem .
OhaRe is offline
post #4 of 13 (permalink) Old 05-31-2012, 03:45 PM
so to install a 2006 crf clutch on my 2005 trx450r i would just need to install the new 2006 crf450r clutch plates without the judder spring and judder seat? is there anything else i would need to do to my clutch. crf450r clutch springs? any mods to the clutch basket?
snekee is offline
post #5 of 13 (permalink) Old 05-31-2012, 03:45 PM
i have a tusk crf kit with cr500 springs with the judder spring out and it rules. Can't say about the durability yet though
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Venom 12.4:1 97mm piston / Balanced Honda revised crank
Stage 2 hotcam
CRF450 clutch / CR500 springs / Trinity cover
UNI filter
Cut airbox lid w/ outerwears
R&D Fuel screw (2 turns out)
Jetting : 185 Main, 50 pilot, HRC needle third clip
Fox FLOAT Evol shocks / Lonestar DC4 arms
Pro-taper bars / Fly grips / Powermadd guards
Moose bumper
Maxxis Razr tires
D3n1s is offline
post #6 of 13 (permalink) Old 05-31-2012, 03:59 PM
That One Mod
ghott's Avatar
Yes, you use all '06 CRF450R fibers/steels, no judder spring.
It would be good to upgrade your clutch springs at the same time. You can use anything from CR500 springs to Dark Synergy or Tokyo Mods springs. Depends on how much hp/tq your engine makes and how you want the clutch pull to feel.
No mods to the clutch basket are required. If your clutch basket is deeply notched, get a new one or file it down.
Gary
ghott is offline
post #7 of 13 (permalink) Old 05-31-2012, 04:49 PM
thanks for the info. where would the notching occur?
snekee is offline
post #8 of 13 (permalink) Old 05-31-2012, 05:00 PM
That One Mod
ghott's Avatar
Gary
ghott is offline
post #9 of 13 (permalink) Old 07-26-2012, 02:45 PM
Send a message via AIM to adam2562
nobody mentions anything about the Vesrah kits.. i was told it was good and i bought one that i just received
07 TRX450ER
-Lonestar carrier, Vesrah clutch, Wiseco Basket, MSR clutch lever, Renthal Chain, K&N filter, FMF slip-on, HID headlights.
adam2562 is offline
post #10 of 13 (permalink) Old 07-26-2012, 02:52 PM
forced entry
nuckinfuts's Avatar
I can tell you exactly why... price! No way would I spend that much when a tusk crf clutch with springs for 1/3 the price will take all I can throw at it!
nuckinfuts is offline
post #11 of 13 (permalink) Old 07-27-2012, 05:44 PM
here's the notching that's occuring on my Basket.. it seems REALLY bad lol
07 TRX450ER
adam2562 is offline
post #12 of 13 (permalink) Old 07-27-2012, 07:33 PM
forced entry
nuckinfuts's Avatar
That's a great example of bad grooving! It usually affects engagment and dis-engagement when worn that bad. That basket is bad enough to need a replacement but in some cases where it's just slightly grooved, you can carefully take a flat steel file and smoothen the basket grooves to get more life from it.
post #13 of 13 (permalink) Old 08-02-2012, 12:25 PM
h0nda450mainiac's Avatar
Garage
Ive used tusk but i keep going through them. Anyone have any luck with the barnett carbon fiber dirt digger?
06 ER
22x11x8 9 paddle
Green wire mod.
AC nerfs.
ESR exhaust, with mid-top end header.
HCII
K&N intake
LRD needle, 4th clip
CR 500 Springs
g force extended hubs
SLC +2.5 swinger
OEM, crf 450r clutch
h0nda450mainiac is offline
