hard to start when hot - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 22 (permalink) Old 03-07-2012, 09:00 PM Thread Starter
Ok guys have a 08 450er ive noticed after riding awhile its little harder to start any suggestions
450er8108 is offline
post #2 of 22 (permalink) Old 03-07-2012, 09:09 PM
09trx450r's Avatar
Check your valve adjustment, its a good starting point.
09trx450r is offline
post #3 of 22 (permalink) Old 03-07-2012, 09:30 PM
Full Throttle's Avatar
a motor tuned on the lean side will be harder to start as well when hot. try pumping the gas 1 time before you start it hot next time, note before not during do not touch the gas while cranking.
Full Throttle is offline
post #4 of 22 (permalink) Old 03-07-2012, 10:18 PM
450r Dunner
jimmy450r's Avatar
bet intakes are tight
06 trx450r
2013 crf450r
2009 crf150r
08 trx400ex
08 trx250ex
2011 rzr S LE
jimmy450r is offline
post #5 of 22 (permalink) Old 03-07-2012, 10:28 PM
Garage
Are you trying to start it in gear with a slightly worn out clutch? Or a bad clutch adjustment? You might be trying to move your quad as well as start it. Try starting it in neutral. Better?
derek_thompson24 is offline
post #6 of 22 (permalink) Old 03-07-2012, 10:59 PM
450r XC Rider
pwalston25's Avatar
any mods? i would say pilot jet is off or needs a valve adjustment
"Ride or don't...Never quit"
08r with 06er engine
Racer's Edge AZ Head and Carb
CP Piston and Stage 3 HC
Full Hinson Clutch
Fox Float X Kashima
Houser +1 XC LT Arms
Fox Podium 2 with Derisi LT link
Precision Pro Stabilizer
Douglas G2 Beadlocks/Kenda Klaws
Houser nerfs, stem, and grab bar
Way Too Much More To List and More To Come
pwalston25 is offline
post #7 of 22 (permalink) Old 03-08-2012, 07:52 AM Thread Starter
Mods are green wire mod uni filter no lid full nmotion exhaust its got oversized rad polished cases just got the bike it dosent pop or backfire at any time so would that mean its tuned right
post #8 of 22 (permalink) Old 03-08-2012, 07:53 AM Thread Starter
Dnt now if its got motor work or not runs great just hard to start when hot
post #9 of 22 (permalink) Old 03-08-2012, 08:53 AM
oneill_1952's Avatar
Send a message via MSN to oneill_1952
Bad jetting.... Pull the carb and find out what size pilot and main it has in it.
2006 TRX450ER
Spending money I don't have, on a quad I barely ride, to impress people I don't even know...
oneill_1952 is offline
post #10 of 22 (permalink) Old 03-08-2012, 09:45 AM
DPCones's Avatar
Could be your stator. How long do you usually have to let it sit before it fires up again?
100% DUNER DORK!!!
DPCones is offline
post #11 of 22 (permalink) Old 03-08-2012, 09:47 AM
08s dont have hot start right?
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Venom 12.4:1 97mm piston / Balanced Honda revised crank
Stage 2 hotcam
CRF450 clutch / CR500 springs / Trinity cover
UNI filter
Cut airbox lid w/ outerwears
R&D Fuel screw (2 turns out)
Jetting : 185 Main, 50 pilot, HRC needle third clip
Fox FLOAT Evol shocks / Lonestar DC4 arms
Pro-taper bars / Fly grips / Powermadd guards
Moose bumper
Maxxis Razr tires
D3n1s is offline
post #12 of 22 (permalink) Old 03-08-2012, 09:50 AM
Banned
i don't believe they do, that was going to be my first suggestion, but wasn't sure if they had them.
ridingred is offline
post #13 of 22 (permalink) Old 03-08-2012, 09:56 AM
DPCones's Avatar
Nope
100% DUNER DORK!!!
DPCones is offline
post #14 of 22 (permalink) Old 03-08-2012, 09:58 AM
Garage
These are all good suggestions. Best mechanical thing to do is check the easiest possible source of the problem first. Kinda like when you don't have spark to check your spark plug before you replace a CDI.. lol.
I'd check all of the above suggestions starting from easiest to hardest. All good info.
post #15 of 22 (permalink) Old 03-08-2012, 10:38 AM
i use my hot start all the time it's sad that gen 2s don't have one. Like Derek said, all above suggestions are good, start with the easiest!
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Stage 2 hotcam
UNI filter
Moose bumper
Maxxis Razr tires
D3n1s is offline
