weak spark - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 01-30-2012, 01:29 AM Thread Starter
weak spark
Hi I have an 07 er that I am considering beating with a hammer....It doesnt want to start valves are good decomp is good. I have been having problems getting it to start for a while now most recently just put a new plug in it and it started fine ran it for maybe 30 mins then put it up now same thing again. I noticed it has a weak spark (more orange than blue) so im thinking maybe the stator or a bad connection. My question is what stator to go with if it is bad. Ricky stator, oem, others? Thanks for any input
07 450er hrc kit,+1x4 valves,42.5 fcr, porting and carb done by racers edge,hc3,+3 bore/477, white bros mx4 exh, uni and outerwear pre
dtmccray is offline
post #2 of 3 (permalink) Old 01-30-2012, 01:47 AM
09trx450r's Avatar
I would go oem If you get a service manual it might walk you through to find out your problem. I don't think it would be your stator put a good charge on the battery. Maybe its your coil and go over all your connections.
09trx450r is offline
post #3 of 3 (permalink) Old 01-31-2012, 07:38 AM Thread Starter
any other opinions?
dtmccray is offline
