02 CRF450 cam in TRX450 - Honda TRX Forums: Honda TRX 450R Forum
Old 12-09-2011, 08:54 PM   #1 (permalink)
bparth19's Avatar
Default 02 CRF450 cam in TRX450
I saw on moto x perts site that they use these cams in I think 90% of their xc/recreational R's but has anyone done this on the org. Was thinking about the 02 crf cam or a HRC cam.
BRANDON
07 450R
bparth19 is offline   Reply With Quote
Old 12-09-2011, 08:58 PM   #2 (permalink)
skipnation's Avatar
Default
I tried one in my 07 and advise you strongly not to waste your time unless you like your 4 stroke to feel like a 2 stroke. It puts the power near the chip and loses mucho torque. It would probably be good with a 14.5.1 piston and you want dyno numbers or drag race.
Four wheeels are better than two
skipnation is offline   Reply With Quote
Old 12-09-2011, 08:58 PM   #3 (permalink)
Default
I run the 02 crf in my mx build. Works good. I have liked it so far but my next engine is getting a new cam. Either a web 208 or a megacycle havent decided yet. What mods do you have and what kinda riding do you do?
bdoyle52 is offline   Reply With Quote
Old 12-09-2011, 09:07 PM   #4 (permalink)
bparth19's Avatar
Default
motor wise i'm working on an exhaust, cam, intake and maybe some other things just the usual stuff I guess but I mostly do woods riding and just kinda freeride at the parks I go to here in missouri but wanting to venture out into some other parks in the neighboring states and maybe do some racing sometime.
BRANDON
07 450R
Old 12-10-2011, 12:40 AM   #5 (permalink)
norcal450's Avatar
Default
I run it in my 05 and I love it. I had previously run an hrc cam but the crf cam feels better all through the power band, especially noticeable more low and mid power compared to the hrc.
I haven't heard too many people running the 02 crf in the 06+ though.
I'm pretty sure there is a sticky in the engine section breaking down the cams you should check out also.
2005 trx 450r
02 CRF Cam......06 FCR Carb......Fuel ATV Intake......ESR Full Exhaust System......CP 12:1 Piston......Venom Performance Port and Polish......JD Performance +2 A-Arms......Works Triple Rate Springs......GTThunder Rear Link......Jet Dual Rate Rear
norcal450 is offline   Reply With Quote
Old 12-10-2011, 12:45 AM   #6 (permalink)
bparth19's Avatar
Default
alright i will check it out see if i come up with anything im not sure what years the moto x perts quads i was talking about are when they use the 02 crf cam.
BRANDON
07 450R
Old 12-10-2011, 02:36 AM   #7 (permalink)
hawk-trx's Avatar
Default
your the first person i have ever heard say that about the 02 cam. i cant disagree with you because i dont know if it performs that different in a 07 then it does in a 04 but it was far from a 2 stroke feel or top end cam in my 04. i cant say i really liked it but i thought it was middle of the road boring cam. i like the 06 hrc better for mx/woods and bottom end feel, and the 04 hrc for dunes/drags and top end feel. but its been said many times different parts will perform different from one build to the next.
hawk-trx is offline   Reply With Quote
Old 12-10-2011, 08:50 AM   #8 (permalink)
skipnation's Avatar
Default
I heard lots of people saying this was a great cam so I tried it on a pump gas big bore build and even raced one mx race. It was weak on the low and came on like a 2 stroke in the upper mids. I tried 7 cams in comparison(HC1, 02CRF,03 CRF, HRC,HC2,HRC, 02crf) so I would actually know what each one felt like within a 6 month period.
I came to the conclusion that the people that loved the 02 had to be running 04-05 TRX. .. OR, have high compression piston to make up for the power loss down low. I have never heard anyone (that races) say this is good in an 06+ on pump gas... especially for torque. If people want to come forward and share different experience, I am open to that, but thats what I found.
Old 12-10-2011, 09:36 AM   #9 (permalink)
Default
skip. youre right about the 02 crf cam is better for the 04 05. you need a newer model crf cam for the 06+ trx. all i know is that my 05 got a huge wake up call with the 02 crf cam
nlb1192 is offline   Reply With Quote
Old 12-10-2011, 10:09 AM   #10 (permalink)
TTownQuad's Avatar
Send a message via Yahoo to TTownQuad
Default
I got a 05 with a early HRC cam. just got the motor back together last month and have been out at the track testing it out. So far i am happy with it, i did have a HotCamII in it before but the rocker arm bearing failed and damaged it, so thats when i switched to the HRC. Heard there almost identical. But after reading the posts from the guys running a CRF cam, i am almost tempted to try.
@ NORCAL 450 you had said that you had a HRC cam before you switched to the CRF. Was it a big noticable differance? or just slight?
Rut!
TTownQuad is offline   Reply With Quote
Old 12-10-2011, 01:35 PM   #11 (permalink)
Keep er pegged
loud450man's Avatar
Default
i got one thatks skip and cant wait to try it but if i dont like it i will got to hcstage 2 since im about mid-topend pull
mx built 450r...flux capacitor
loud450man is offline   Reply With Quote
Old 12-10-2011, 03:36 PM   #12 (permalink)
skipnation's Avatar
Default
CRF450 CRF450R CRF 450 OEM Camshaft Cam Shaft 03-06 14110-MEN-670 | eBay
If anyone wants a mint 02 CRF cam less than 100 dollars,
Here is one on ebay listed as 03-06 CRF cam but,
You can tell by the photo that its an 02 because there is no grooves.
Old 12-10-2011, 03:50 PM   #13 (permalink)
Default
I had an 02 CRF cam in my 07 for a while but got tired of it. If you want a lot of top end and want a "2-stroke" feel, go for it. I now have the 06+ HRC cam and love it. The HRC cam has a broader range of power and produces more usable torque across the entire powerband. Sounds to me like the 06+ cam would work great for you. Good luck.
2007 TRX 450 ER
HiPer wheels w/ XCR's
HRC Cam
HMF Competition Series Exhaust
Spark Filter
Dominator II
ARS FX +1 Steering Stem and Clamp
X-Factor Front Bumper
JET Re-Valved Shocks
XC Link
Tag CR High-Bend Bars
Pro Armor Nerfs
PRM Skids
2005 TRX450R (Sold)
ITP HD Tires
Black Baja Fronts
IMS Roll Front Bumper
Pro Taper Bars
Pro Armor Skid Plates
dracnik is offline   Reply With Quote
Old 12-10-2011, 03:59 PM   #14 (permalink)
norcal450's Avatar
Default
I noticed a bigger low and mid gain when I switched to the crf cam and the top end pull was more gradual. The hrc cam just seemed to hit hard on the top end.
I also swapped the stock carb to an 06 fcr carb when I switched cams but just the carb swap is not supposed to add power anywhere just better throttle response.
2005 trx 450r
Old 12-10-2011, 08:01 PM   #15 (permalink)
TTownQuad's Avatar
Default
I too did the carb swap. much better throttle responce. thanks for taking the time to leave your feedback on your experiance with that cam. im going to run that HRC for alittle while longer since i just got it. but im going to be in the market for a 02 CRF cam..
thanks agian...
Rut!
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
