motors cuts out/bogs on high rpm - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 6 (permalink) Old 10-15-2011, 03:14 PM Thread Starter
dsconant's Avatar
I cant figure out whats going on with my quad. It ran fine before it sat for a couple months. When I went to ride it you couldnt even go to 1/2 throttle in any gear. I took the carb apart and cleaned it up now it wont run right at high rpm. Any help would be appreciated.
05 Kicker
Rossier exhaust
Lonestar DC4 +2+1 arms
G-Force + 4 Axle
Elka quad rate piggyback shocks
Revalved stock rear with MX Link
K&N Filter
Tag oversized bar mounts
Tusk Chub Bars
Pro Armor Nerfs
dsconant is offline
post #2 of 6 (permalink) Old 10-15-2011, 03:17 PM
rocknhorse76's Avatar
Either the main jet circuit is still clogged up, or you messed up the float level and its starving for fuel at high rpms.
07 TRX470ER
14.4:1 98mm CP piston
Dasa custom ported head with Ferrea SS valves
Web 242/921
Web HD dual valve springs/ ti keepers
Dasa 43.25mm FCR
Dasa intake
Dasa Classic Exhaust
JD +2 ST A-arms
Elka Stage 3 Dune Series shocks F/R
QUIKSHRK (OCP) +4 arched ladder swinger w/Derisi link
G Force axle
Pro Taper Contour CR Hi bars
Houser +2 stem
HID headlights
rocknhorse76 is offline
post #3 of 6 (permalink) Old 10-15-2011, 05:05 PM
miller67's Avatar
also try turning your air/fuel screw in all the way and bring it back out 1 1/4 turn, also replace the spark plug, a plug going bad can cause it too cut out when running.
2004 TRX450r
-HMF Eliptical Polished Slip-on
-K&N w/outerwear and lid off
-180 main dyno jet
-Tusk nerfs
-Renthal race bend bars silver
-Duncan front bumper
-Skat Trak 20x10-10 8 paddle extreme grip haulers on .190 douglas rims
miller67 is offline
post #4 of 6 (permalink) Old 10-15-2011, 07:56 PM
You might want to also check the petcock. I have an 05 that sat for a couple years and last year I checked several things to prep for a ride on the dunes. I pulled the carb and cleaned all the jets and also pulled the petcock out of the tank just to check it, the petcock screen appeared mangled / deteriorated but after cleaning the jets she fired right up and seemed to run OK around the parking lot so I loaded her up and I was off to Sand Mountain. At the dunes she repeatedly seemed to be starving for gas intermittently at high RPM's. Today I'm preparing for another Sand Mountain trip so first I replaced the entire petcock with new and this appears to have solved the issue, full throttle up and down the street several times through all gears, no hesitation, no starving for fuel, WAAAHOOOO! Now I gotta pull out the new 04 that has sat for the last 7 years and see If she's gonna cooperate.
TRX1300R is offline
post #5 of 6 (permalink) Old 12-18-2013, 05:28 PM
hey I'm having the same problem with my quad. what was the solution you came up with??
Thanks, Kyle
kalvarez2 is offline
post #6 of 6 (permalink) Old 12-18-2013, 06:22 PM
sb/ss pump gas kickin ass
bigcountrydude's Avatar
what are your mods and jetting? too big of a main jet will cause this also.
Chrome valve stem caps.
bigcountrydude is offline
