13:1 JE piston - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 34 (permalink) Old 02-14-2011, 11:00 PM Thread Starter
sparks 450r's Avatar
13:1 JE piston
with this piston what octane should i really run i have heard 91 to 112? Could i get away with 104? Also what will happen if i don't run high enough octane? Lastly how often should i change the rings if i ride about twice a month hard?
thanks
colton
2004-2005 honda 450r
Sparks Full Exhaust
ESR Modded Intake (air box mod lid off)
JE: 13:1 piston
Stage 2 hot cam
DG full underbody protection
DG nerf bars with heel guards
DG front bumper
14 tooth front
D.I.D gold ring chain
Pro design teather
Pro Taper contuar bars
Billet case saver
Billet brake block off
Kenda Kutter XC tires all around
Race cut front finders
jetting main 192
Pilot 50
needle 2nd richest
sparks 450r is offline
post #2 of 34 (permalink) Old 02-14-2011, 11:16 PM
OCP
Oregon Coast Powersports
OCP's Avatar
Send a message via Yahoo to OCP
if you dont have enough octane, you can get into detonation. detonation is a very destructive. it is an extremely violent explosion that will destroy pistons, heads, cranks, rods/bearings, and cases. i would say that you are borderline on running pump gas safely. i would mix it with 110 to be safe. 60 pump/40 race would be fine imo.
OCP is offline
post #3 of 34 (permalink) Old 02-14-2011, 11:20 PM
sb/ss pump gas kickin ass
bigcountrydude's Avatar
i run 93 in my 13.5:1 comp. no detonation. so u should be safe on pump.
#224
Chrome valve stem caps.
#RememberTheBuster
bigcountrydude is offline
post #4 of 34 (permalink) Old 02-14-2011, 11:23 PM
on my old 05 had the same piston and some other decent amount of mods and just ran 93 nothing else ran amazing so id say your good
k3vmaster is offline
post #5 of 34 (permalink) Old 02-14-2011, 11:30 PM
Fairly fast foreigner!
OTMTRX's Avatar
I'd be careful.. maybe call JE and tell them your build..see what they recommend.
If you do start mixing 91 / race gas... here's a cheeky little calculator..
ranney.com - Fuel Blending Calculator
'06 TRX450ER, '03 XR400r, '04 CRF450r, '05 CRF250r, '06 CBR1000RR (StreetFighter), 07 GSX-R750, '71 CB500, '75 CL360 (Honda Scrambler), '81 Virago XV750 (the 110 Bike).
06 Black TRX450ER (Conv to kicker) "Medium" Big bore! Quikshrk (OCP), Demon, REAZ bits.
OTMTRX is offline
post #6 of 34 (permalink) Old 02-15-2011, 08:27 AM
TRX450R14's Avatar
That is a bit presumptuous to suggest that he can run at that comp ratio just because you can....unless he is running the exact same setup as you....and even then,altitude,temps or a bad batch of gas can change that real quick.
A good rule of thumb is 12.5:1 for pump gas...but running at a higher comp can be done...if you are willing to put in the time and effort to test/tune.
Team X Racing....we don't just race....we ride.
There's no room for "one trick ponies" in our stable.
Walk softly and carry a big stick.
True power IS in the head....it's called a brain.
2011 1/8th mile ATV Drag video...
The fastest,most reliable trail quads on the east coast.
TRX450R14 is offline
post #7 of 34 (permalink) Old 02-15-2011, 10:21 AM
Banned
i have the same piston and ive been running 93oct for the past 3months. after reading this im kind of leaning towards higher oct. but i dont have any around me right now. would Pj1 octane booster work?
Westtt80 is offline
post #8 of 34 (permalink) Old 02-15-2011, 11:34 AM
08TRX's Avatar
I had a buddy who used the octane boost with 91 octane on his YFZ and it ran TERRIBLE. He's running the high comp. JE and he switched over to running 110 and it runs perfect. The mechanic who did the build, and i'm not saying that yours has the exact same build, recommended running 110..hope this helps!
'08 TRX450ER - FOR SALE
Hot Rods +3mm Stroker Crank
Cylinder Works 99mm Cylinder
Custom 99mm JE Piston 14:1
Head Ported by Venom
Custom Web Cam
Webcam Dual Spring Kit
Full Dasa Exhaust
Velosity Intake
Wiseco Billet Clutch Basket
Fasstco Flexx Bars
White Laker Plastics
Black Laker Hood
Quadtech Seat
AC Black-Line Nerfs
Much More..
"The guy everyone calls when they break something"
08TRX is offline
post #9 of 34 (permalink) Old 02-15-2011, 11:37 AM
Banned
okay thanks. i just have to find 110 now
Westtt80 is offline
post #10 of 34 (permalink) Old 02-15-2011, 11:45 AM
TRX450R14's Avatar
You are running the 04/05 HRC cam...so you can actually get away with running at that comp fairly safely...due to the amount of overlap....but having some good octane boost or race gas to mix would be a good idea for added protection....just make sure whatever you use actually raises the octane rating by a full points...not a few .10ths of a point.
...but ,once again...it's not a "one size fits all"...when it comes to octane requirements...so always error on the side of caution if you are unsure.
Good luck
post #11 of 34 (permalink) Old 02-15-2011, 11:49 AM
Banned
My friends all run the PJ1 octane booster in their 2 stroke dirtbikes. but ill be okay if i run lik 100 octane right? i can get that when race season starts.
Westtt80 is offline
post #12 of 34 (permalink) Old 02-15-2011, 11:53 AM
TRX450R14's Avatar
Yes...a 50/50 mix or maybe even a 75/25 pump gas/100 octane would probably be fine.
post #13 of 34 (permalink) Old 02-15-2011, 11:58 AM
i was just assuming but i guess u know what happeens when i do that . . .
#224
#RememberTheBuster
post #14 of 34 (permalink) Old 02-15-2011, 12:40 PM
TRX450R14's Avatar
lol...yeah,I know....I just don't want the guy to have any deto issues if we can help it.
post #15 of 34 (permalink) Old 02-15-2011, 01:02 PM
OTMTRX's Avatar
I know on the Venom site they say 105+ octane for their 14.5:1 piston. So at 13.5:1 100 should be ok...if that helps...info only!
OTMTRX is offline
